Swapping D44a axles, anything funny about swapping their brakes? - JeepForum.com
post #1 of 10 Old 02-25-2009, 11:35 AM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
So my son cracked his 2002 WJ's D44a's aluminum pumpkin on the bottom when he slammed it into a rock. I have a replacement D44a axle but it has drum brakes where my son's D44a has disk brakes. I'd probably be ok with just using the drum brakes but they didn't come with the drums themselves, I'd have to buy them so I'd rather not since I have a perfectly good set of disk brakes on the original axle.
Swapping between disk and drum is easy on a standard Dana 44 which I've done on my TJ, but what about this c-clipped D44a? Is it the same process? Is there anything more to the swap than unbolting the drum brake's backing plate and bolting up the disk brake assembly?
No advice to dump the D44a and go for a "real" D44 is needed here, you'd be preaching to the choir and I got the replacement D44a for free. Thanks in advance guys.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #2 of 10 Old 02-25-2009, 11:38 AM
CLNinja
CLNinja's Avatar
i dont think ive ever seen a D44a with drums instead of disc... what did it come off of? thats interesting
( sorry that i have no helpful advice )
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #3 of 10 Old 02-25-2009, 12:01 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Yeah, I cannot think of any D44a that would have drums, even if it came from a ZJ (which will not work if this is going to a WJ).
Also, the WJ axles are not c-clipped like the ZJ. Just 4 bolts on the outer flange of the axle that retain the shaft, like your TJ D44.
*edit* unless the rotors are removed and what you are seeing is the e-brake set up?
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #4 of 10 Old 02-25-2009, 12:12 PM Thread Starter
Jerry Bransford
Administrator
Oh yeah cool!! Now that I think about what I saw, you're absolutely right!
I just glanced at the axle for a split second as I passed by it late last night (it got delivered by a friend while I was at work) and now remember the brake shoes I saw were too small for drum brakes. Yep, they were the parking brake shoes I saw. I just need to get some rotors for them now, what a relief. Thanks!!
Getting
post #5 of 10 Old 02-25-2009, 02:49 PM
CLNinja
CLNinja's Avatar
good lol... i was confused when you said D44a with drums
glad the job will be easier for you now
is the D44a out of a WJ or a ZJ though?
Matt
CLNinja is offline
post #6 of 10 Old 02-25-2009, 04:16 PM Thread Starter
Jerry Bransford
Administrator
Crap I finally had a few seconds to look it over more closely and it needs both the calipers and rotors. I'll just transfer the brakes and rotors off the old axle, no big deal. So far as as I know, it's off a WJ.
Getting
post #7 of 10 Old 02-25-2009, 04:21 PM
trailblaze
trailblaze's Avatar
yeah i was confused too with the c-clip and drums...
anyway.. have fun wrenching.
Matt
trailblaze is offline
post #8 of 10 Old 02-25-2009, 07:20 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
A quick look will be on top of the center section will be a mount for the A-arm (for WJ).
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #9 of 10 Old 02-26-2009, 02:24 AM
sandman
you should look at putting a skid on it so he doesnt crack it again.
1993 Jeep ZJ. 4.0
sandman is offline
post #10 of 10 Old 02-26-2009, 08:40 AM Thread Starter
Jerry Bransford
Administrator
It's a 2wd GC with street tires, he knew better than to take it where he did since we have the TJ for offroading. He won't be doing it again or he'll find his *** in boot camp.
Getting
Swapping in D44a.. few questions MoonyJohn ZJ Grand Cherokee Forum 66 10-23-2009 04:19 PM
Swapping SRT8 Brakes onto Laredo? donk_316 WK Grand Cherokee & XK Commander Forum 1 09-08-2009 06:24 PM
Swapping axles in a WJ jopolly3 ZJ Grand Cherokee Forum 12 06-08-2009 11:45 AM
Swapping rear axles SnowLeopard ZJ Grand Cherokee Forum 3 04-15-2009 10:31 AM
Swapping D44a into ZJ from WJ zjilla ZJ Grand Cherokee Forum 6 01-22-2009 08:45 PM
