Swapping in a 231 into a WJ - JeepForum.com
post #1 of 4 Old 04-14-2009, 09:57 PM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
So what vehicle does it need to from? I know it can be done but don't know what vehicle to get it from. Could someone enlighten me?
Brian
WJ, WK, CJ5
GraKee99 is offline
post #2 of 4 Old 04-14-2009, 10:46 PM
StrokedWJ
StrokedWJ's Avatar
I'm curious as well...I'd assume a late model TJ or XJ. Whats the spline count on the TC input 23?
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 4 Old 04-15-2009, 01:40 AM
redlaxin18
I'm not 100% positive if I'm gonna remember all this correctly since its been a while since I did all the research for the 247-->231 swap. I'm pretty sure it has to be a 95+ model because of the gear cut or something like that. I'm also pretty sure it needs to be from a 6 cylinder power plant because of the spline count if I remember correctly. Both the 247 and the 231 have 23 spline inputs however the 231s standard input shaft is to short for the 545RFE tranny. So once you pull the 247 you have to tear it and the 231 apart and swap the 247s input into the 231 case (its a direct swap). You'll also need to fabricate a new linkage setup because the 247s shifter linkage won't go through the entire gear range on the 231. There might be a way to do the swap without doin an SYE of some sort but I don't really see why you would. I think someone told me there's a way to modify the WJ rear drive shaft to work with the 231 but I went a head and had a multiple double cardan shaft made. I prolly left something important out so feel free to ask me any questions and I'm gonna try to find the links the helped me through the swap.
Broke College Kid
99 V8 WJ ---> NP231 w/sye, 4.5" (KOR Lift) , 285/75/R16 Maxxis Bighorns, Front & Rear Woody Shafts, Kolak exhaust w/FM50, K&N FIPK, CB, KOR Rack w/Daylighters, Aussie Locked D44a
Future Mods: Sliders, Homebrew Long-Arm, Front Aussie Locker, Homebrew Bumper with Winch
redlaxin18 is offline
post #4 of 4 Old 04-15-2009, 07:37 AM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
Ya the 247 and the 231 are 23 spline inputs so they are a direct swap and there is an SYE kit you can get with for the 231 that will work with the WJ. The shift tab for the 231 must be modified a bit though. I figured it had to be a late model TJ or XJ, just seeing if anyone knew for sure.
Brian
WJ, WK, CJ5
GraKee99 is offline
swapping my 5.2 v8 with a 5.9 v8 - please help!! SouthAfricaJeep ZJ Grand Cherokee Forum 119 10-13-2016 01:19 PM
Swapping D44a axles, anything funny about swapping their brakes? Jerry Bransford ZJ Grand Cherokee Forum 9 02-26-2009 08:40 AM
Swapping a 4.7HO into a non-HO WJ? AgitatedPancake ZJ Grand Cherokee Forum 1 02-02-2008 01:37 PM
Wj rim swapping B_palmer22 ZJ Grand Cherokee Forum 11 12-16-2007 09:02 PM
Swapping a 4.0 for a V8? Firegod14 ZJ Grand Cherokee Forum 53 03-29-2007 10:14 AM
