swapped to a 242 today... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > swapped to a 242 today...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military DiscCurrie Currectlync Steering Upgrade Kits and Currie Anti-R
Unread 07-20-2007, 09:35 PM   #1
tmorg
well i finally broke down and bought me a zj, my first, its a 95 orvis edition with just over 200k. i had an old volkswagen that i never used, and a guy traded me even for it. i immediately couldnt stand full time 4wd, so i bought a np242 from a salvage yard. the swap was relatively easy, i read the instructions on jeephorizon, although this case was a selectrac from a 93 cherokee, the splines were the same, the length of the case was the same as well. the only problem im having now is the linkage. the linkage lever will move to 5 different settings and im not sure why. i didnt have time to figure them out today, i just assumed it would be 2wd, 4hi, N, and 4lo. ill have to play with them tomorrow to get it set correctly.
tmorg is offline   Reply With Quote
Unread 07-20-2007, 09:40 PM   #2
BradMB2004
the 242 case is 2wd, part time 4hi, full time 4hi, n, 4lo
this is a pic from a WJ, but the pattern is the same.
Brad
2004 Wrangler X
2001 Grand Cherokee Ltd.
1997 Grand Cherokee Ltd.
BradMB2004 is offline   Reply With Quote
Unread 07-20-2007, 10:25 PM   #3
tmorg
well... that clears that up, id never seen that, i thought they were all just 4 settings. thank you for clearing that up!
