Swap offset rear d60 into WJ? - JeepForum.com
post #1 of 28 Old 10-15-2007, 08:03 PM Thread Starter
wheelNC93
I've been looking for a d60 to swap into the back of a wj. There is a d60 out of a j-20 and the diff has a 6in. offset. Will this be ok in the back of it as long as the ds is the right length, or should I just look for a different 60?
Thanks
Brandon
94 GC Laredo 5.2L -BDS 6.5" coils-TeraFlex upper and Lower Adj. Control arms F&R-TrXus 33x12.5x15 on 15x8 rockcrawlersz -TeraFlex Discos-JKS adj. trackbars-249<242 swap (in progress)-RRO t-case skid-off road warehouse sliders-Custom roofrack - 4 Hella 500's - herculined interior
wheelNC93 is offline
post #2 of 28 Old 10-15-2007, 08:44 PM
nierace
nierace's Avatar
2003 WJ
I'm not sure, but I think you're gonna have issues....
You're probably better off looking for a Ford 9" to throw out back, however with that you need to make modifications to the gas tank I believe in order for the pumpkin to clear.
Check out www.mallcrawlin.com
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 28 Old 10-15-2007, 10:46 PM
99grand4.0
1997 XJ Cherokee
id go with something other than a 9", from hot rod experience nobody likes them because of the high heat they generate and how much power they rob, but just my 2 cents. id look for a dana.
99grand4.0 is offline
post #4 of 28 Old 10-15-2007, 11:40 PM
FortCollinsZJ
what about 8.8's? they get hot? and as far as robbing power... wha? how?
FortCollinsZJ is offline
post #5 of 28 Old 10-16-2007, 08:22 AM Thread Starter
wheelNC93
I want something alittle bit stronger than a 8.8. There are 37s on it so I think i'm better off with a 60.
post #6 of 28 Old 10-16-2007, 08:40 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
As far as drive shaft angles go, the 6 inch offset will not have any negative effects, our rear drive shafts are a mile long.
However, rear 60's are a dime a dozen, get one that will be easier to work with.
As far as the 9" comment, what? If they rob so much power, I guess you should clue NASCAR into this phenomenon and the many other performance organizations across the globe.
A 9" can be a fine choice for a center section to use, they have tons of aftermarket support, they are plenty strong, and have many axle spline and gear ratio options.
One thing to consider, if you are already on 37's, don't waste your time with 30 spline axles in the rear. You can get away with it in the front if you feel like swapping in a D44, but most who swap in D44's wish they went 60 or hybrid custom soon after.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #7 of 28 Old 10-16-2007, 12:11 PM Thread Starter
wheelNC93
So your saying for the front I could get away with a 44 but will eventually want a 60? But in the rear just try and go with a 35 spline, forget the offset 60.
post #8 of 28 Old 10-16-2007, 12:19 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
not to meantions WJ's get there speedo reading from the rear axle...
2013 FR-S
BlaineWasHere is offline
post #9 of 28 Old 10-16-2007, 12:24 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Or maybe he could call Currie Enterprises and get their input on the matter...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #10 of 28 Old 10-16-2007, 02:34 PM Thread Starter
wheelNC93
Not to worried about the speedo as it will be a trail rig only.
post #11 of 28 Old 10-16-2007, 02:34 PM
MuddyLuxury
MuddyLuxury's Avatar
you sure about that?
the tru speed attachs to the trans
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #12 of 28 Old 10-16-2007, 02:38 PM Thread Starter
wheelNC93
You can also change it so you get your speedo to work off of the t-case, from my understanding, if you really wanted to have it.
post #13 of 28 Old 10-16-2007, 02:47 PM
MuddyLuxury
wait, is this D60 for a WJ or for the ZJ in ur sig?
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #14 of 28 Old 10-16-2007, 03:05 PM
BlaineWasHere
BecauseRacecar
STOP SAYING THAT!!!
It is at the rear axel in WJ's... ask people over a MC that have done rear axle swaps...
2013 FR-S
post #15 of 28 Old 10-16-2007, 04:32 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
Didn't you read the title?
Or the first post?
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
ZJ offset giacomo.m ZJ Grand Cherokee Forum 7 01-12-2010 12:54 AM
Rear end swap abe51 ZJ Grand Cherokee Forum 18 08-02-2009 11:32 AM
Rim Offset jcam91 ZJ Grand Cherokee Forum 4 02-09-2008 01:36 AM
Rear end swap ?'s jeepman75 ZJ Grand Cherokee Forum 9 10-16-2006 10:50 AM
What offset to go with? xxdriverxx ZJ Grand Cherokee Forum 11 11-09-2005 04:40 AM
