Swap D35 with D44a - JeepForum.com
post #1 of 17 Old 05-04-2009, 10:35 PM Thread Starter
WhiteOut
WhiteOut's Avatar
Swap D35 with D44a
Is this swap worth it? I can get a D44a from a 98 5.2 with 3.73 gears, LSD and discs for a couple hundred. The only thing is it has a bad pinion bearing, so it needs a bit of work. What would you guys offer for it.
WhiteOut is offline
post #2 of 17 Old 05-04-2009, 10:57 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
If the gear ratios match your front, worth a hundred or 2 (concidering it has a bad pinion brg), plus your time.
If he's asking 200, offer him 125, settle for 150.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 17 Old 05-04-2009, 11:14 PM
jeepheller98
sounds like a good deal to me, i would kill for it
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
post #4 of 17 Old 05-04-2009, 11:16 PM
GraKee99
Rapist Wit
GraKee99's Avatar
You have a 44a.
I would go no higher than $200 probably, of course try to go lower.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #5 of 17 Old 05-04-2009, 11:17 PM
CLNinja
CLNinja's Avatar
once trussed with a skid plate the 44HD ( 44a ) is stronger than an iron 44 because it eliminates the week points
thicker ring gear.... thicker pinion shaft.... pinion shaft/spline count on a 44a is same as a D60... axle shaft size between d44a and d44 is the same
for less $$$$ than it would take to custom fit an iron 44...you can make the 44a stronger
Dana 60
Ring Gear Diameter = 9.750"
Pinion shaft Diameter = 1.626"
Ring Gear Bolt Count = 12
Pinion Spline = 29
Cover Bolt Count = 10
Dana 44 a
Ring Gear Diameter = 8.5"
Pinion Shaft Diameter = 1.625"
Ring Gear Bolt Count = 10
Pinion Spline = 29
Dana 44 Iron
Ring Gear Diameter=8.500"
Pinion shaft Diameter=1.376"
Ring Gear Bolt Count=10
Pinion Spline=26
Cover Bolt Count=10
__________________________________________________ _____________________
i think it is worth it.......i have done the swap and i love it... i am very confident in my d44a
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #6 of 17 Old 05-04-2009, 11:46 PM Thread Starter
WhiteOut
WhiteOut's Avatar
Is the pinion bearing hard or expensive to fix?
WhiteOut is offline
post #7 of 17 Old 05-05-2009, 12:14 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
it aint hard, but it aint all that cheap if you use quality parts for inner and outer....
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #8 of 17 Old 05-05-2009, 06:51 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I would say it is hard...you need to remove the entire carrier to get to the pinion to replace the bearings. Pull the bearings off (via a bearing puller) and press a new set on (need a press for that).
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #9 of 17 Old 05-05-2009, 07:26 AM
_Kyle_
_Kyle_'s Avatar
I'd pass...there are plenty of 44a's laying around and you could probably even find another built one laying around. I'm looking for one with 4.10s or 4.56s and a locker to swap in and then sell my 44a to a buddy of mine... But then I HAVE to do something up front...HPD30 swap The problem is they are always ridiculously far away from me.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #10 of 17 Old 05-05-2009, 09:01 AM
aaron7
I can't wait to get my d44a.
89 MR2 MK1.5
74 CB360
83 Firebird
79 Dodge Shasta 22' RV
aaron7 is offline
post #11 of 17 Old 05-05-2009, 09:48 AM
SnowLeopard
I've heard opinions on both sides and don't really know what I should do. In the long run I want to put an LSD in my D35. I see a classified on here where someone's selling a rebuilt D44a with a rebuilt trac-loc. But those are crap as far as I can tell and you can't replace them with a Detroit true-trac without a lot of work. This D44a has 4.10 gearing already though. They want $350 and are 5-6 hours away from me. I wonder if I could fit it in the back of my Jeep with the seats out...
I'd probably be best just waiting and getting the lift first, but you see these deals and wonder. If I stick to 31"-32" tires, would the 35 really be enough.
Now I want to regear. But will the 4.10 make enough difference to make it worth it over the 3.73 I have?
Don't mean to hijack your thread here, Fraser. You just voiced some similar questions I had.
I did forget to mention the D44 is from a V8 ZJ, no doubt. So I'm not sure whether that makes a difference.
SnowLeopard is offline
post #12 of 17 Old 05-05-2009, 10:25 AM
JG_Canuck
Didn't all V8 ZJ's come with a 44a? I thought they did...
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #13 of 17 Old 05-05-2009, 10:32 AM
ArloGuthroJeep
Mr. Hyde!
93-95 had the D35 in the back regardless of the engine.
96-98 had a D44a in the back if it was a V8.
post #14 of 17 Old 05-05-2009, 10:39 AM
CLNinja
CLNinja's Avatar
yes i have fit 2 axles at the same time plus tools in the back of my ZJ with the back seats folded down
With 31" tires... 3.73s are just fine...with 31"-32" tires , 4.10 will be better but it isnt a huge difference.... you can however find an HP30 with 4.10s already in it to swap into the front...saving you money and giving you better axles
arlo already answered this one
Matt
CLNinja is offline
post #15 of 17 Old 05-05-2009, 10:54 AM
SnowLeopard
I just know how bad acceleration is going up hills and mountains right now. I don't want to lose that much power. If I'm looking at 10% or more loss, then I might have no choice but to regear before I go up in tire size. I think I'll just go with the lift first though. Then tires next, when my 29's wear out. Then go from there. Either I go into major debt on a credit card to do it all at once, or I just do it one phase every 6 months or so. :P
I want 4.10 now though. I just don't see how changing an axle isn't a major undertaking.
D35-->D44a axle swap ArloGuthroJeep WJ Grand Cherokee Forum 67 11-17-2011 11:27 AM
D44a swap ? bigjeep6303 ZJ Grand Cherokee Forum 5 12-19-2009 01:16 AM
D44a swap into my 93 with drums... ? aaron7 ZJ Grand Cherokee Forum 8 07-01-2009 06:00 PM
1999 wj d44a swap? jplifee ZJ Grand Cherokee Forum 6 05-13-2009 09:28 PM
d44a axle swap bigbluezj94 ZJ Grand Cherokee Forum 3 01-25-2009 04:34 PM
