Swap a '93 42re for a '97 44re? - JeepForum.com
post #1 of 15 Old 03-20-2010, 04:41 PM Thread Starter
PokeyJeep
I have a '97 ZJ with a 44re, which the previous owner abused. The tranny is almost dead and I can't afford a rebuilt transmission, but I found a '93 42re that I'm thinking I can use a rebuild kit to build into a 44re since they are essentially the same thing.
Am I wrong or is this reasonably doable? I am a moderately experienced mechanic, but I have never tried something like this before, and I would really appreciate the input of some wiser minds.
PokeyJeep is offline
post #2 of 15 Old 03-21-2010, 12:35 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
no, the 42re uses weaker internals.
a basic rebuild kit(unless hard parts are broken) is only a few hundred bucks. i have 2 spare trannies if you have a need for hard parts.
ratmonkey is offline
post #3 of 15 Old 03-21-2010, 09:46 AM
baxy
yes you can probably get enough parts between the two with anoverhaul kit to make one trans
baxy is offline
post #4 of 15 Old 03-21-2010, 10:08 AM
comptiger5000
I would just pick up a functional junkyard 44re and a rebuild kit, and re-do the clutches, etc. Then swap it into your Jeep.
comptiger5000 is offline
post #5 of 15 Old 02-02-2011, 03:22 PM Thread Starter
PokeyJeep
you guys are a great help, thank you. we broke up so it doesn't matter anymore, but I really appreciate the advice, I have a '98 4.0 now that I love
post #6 of 15 Old 02-02-2011, 03:40 PM
93zjFBI
if that trans you found is really out of a 93 its not a 42re its an aw-4 trans i have a 93 gc and the trans in it is a aw-4 93 is the ONLY year that got the aw-4 in a gc
93zjFBI is offline
post #7 of 15 Old 02-03-2011, 12:31 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
early 93 had the aw4, after the first few months it changed to the 42re.
post #8 of 15 Old 02-04-2011, 04:47 PM
93zjFBI
i have buddy that works at a jeep dealership and he can back me all 93s have aw-4 trans 94 is the first year for the 42re
93zjFBI is offline
post #9 of 15 Old 02-04-2011, 06:05 PM
CatSplat
1994 ZJ
Well, then you're both wrong. It's well known that'93s had both AW4s and 42REs, the 1993 ZJ factory service manual confirms it, and to top it off I know a guy with a bone-stock 1993 4.0 ZJ with a 42RE. He even has an account here, if you don't believe me.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #10 of 15 Old 02-04-2011, 09:19 PM
Newb1995jeepgc
1994 ZJ
93 was a messed up year for the Grand Cherokee (also the first year for them) they had wierd gear ratios and trannys. Everything was wierd.
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #11 of 15 Old 02-04-2011, 09:23 PM
JrMechanic
Guess my '93 42RE is an exception, right?
Very few 93's came with the AW4. 75% + or - a few came with the 42RE.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #12 of 15 Old 11-15-2011, 04:09 PM
Cornbread1
1933 ZJ
I also have a 42re, you will know once you change the trans fluid (different pan gasket)
Cornbread1 is offline
post #13 of 15 Old 11-15-2011, 04:17 PM
steeleman3
I thought they came with a 46rh possibly too?
Big Gulps huh? Alriight! Welp, see you later!
steeleman3 is offline
post #14 of 15 Old 11-15-2011, 04:36 PM
comptiger5000
^ The AW4 (early 93 only) / 42RE (mid 93 - 95) was for 4.0s, and the 46RH (93 - 95) was used in V8s. Then in 96 - 98, 4.0s had the 42RE, 5.2s had the 44RE, 5.9s (98 only) had the 46RE.
post #15 of 15 Old 11-15-2011, 04:58 PM
steeleman3
^Good info x2. Nice accurate breakdown
42RE Upgrade to 44RE? ZJJay ZJ Grand Cherokee Forum 1 12-25-2009 08:06 PM
Can I swap a 44RE with a 42RE ? weberdm1980 ZJ Grand Cherokee Forum 2 11-18-2009 09:58 PM
44RE in place of 42RE?? HomeSpun ZJ Grand Cherokee Forum 3 03-10-2008 04:07 PM
42re to 44re swap angry troll ZJ Grand Cherokee Forum 6 10-30-2007 09:40 PM
42re-->44re???? legend6009 ZJ Grand Cherokee Forum 4 04-19-2007 02:42 PM
