Suspension Lift w/ Spacers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Suspension Lift w/ Spacers
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-25-2003, 11:17 PM   #1
miker4471
As I've mentioned in other strings, i'm researching a 4.25" or 4.5" lift for my ZJ. Does anyone know about using 1 3/4" spacers (that i currently have) with a lift in the aforementioned height range? I'd like to know if I'm keeping the spacers or just selling them. Any info is appreciated. Thanks.
'94 ZJ Laredo
Red/Gray
1 3/4" BDS Spacers
Rancho RS5000 Shocks
BDS Steering Stabilizer
30x10.50 Cooper Discoverer All Terrain
Husky Liners f/r/c
miker4471 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2003, 06:24 AM   #2
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Keep the spacers.
If you go with either the RE or Tomken lift make sure to upgrade to all adjustable control arms. With the nonadjustable ones, the axles will be moved closer together and the ride quality will suffer. You'll be able to run 33s without trimming or rubbing.
I'm running the 4.5 kit with 2 in bb.
Hunter
00 4.7 Laredo...KYB gas shocks, ADDCO rear sway bar and Firestone Destination tires.
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2003, 07:55 AM   #3
miker4471
Excellent. I was hoping that would work. Thanks.
'94 ZJ Laredo
Red/Gray
1 3/4" BDS Spacers
Husky Liners f/r/c
Unread 04-26-2003, 10:21 AM   #4
Kess
how about 4.5" coils in the front, front coils in the back with a 1.75" spacer.....frist would that settle even?? second would i be able to fit 32s on stocker wheels, without(or very minor) rubbing???thanks
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline   Reply With Quote Quick reply to this message
Unread 04-26-2003, 12:15 PM   #5
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Kess,
I'm not sure how much height you will gain with the stock front coils in the rear.
So, I can't really help you there. Now,
you can run 32s on stock wheels except that they will rub like crazy from the backspacing on your sway bar and your shocks. You could add wheelspacers to push the wheels out further.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
Unread 04-26-2003, 12:20 PM   #6
Kess
im looking to get 4.5" higher than stock....that would be fantastic
Unread 04-27-2003, 08:15 PM   #7
demtjcj
texas zj do you have new driveshafts and is that a tcase skid. if so where can i get aftermarket ones at. thanks
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline   Reply With Quote Quick reply to this message
Unread 04-28-2003, 06:41 AM   #8
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I have the stock driveshafts that luckily are u-jointed vice the cv boot.
I bought the tcase skid through www.jpparts.com. I bought the gas tank skid at a u-pull-it junkyard for 36 bucks.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
Unread 05-05-2003, 09:37 PM   #9
REDDOG55
i got a 95 Zj..i want to add 3 or 3.5 inch lift..with 2inch spacers.can i fit 33's and what width..thanks
REDDOG55 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2003, 07:38 AM   #10
KillerZJ
I have heard you can run a 2" BB and 33" tires no problem...is that true???
[FONT=Century Gothic]Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only. hbluthi@presby.edu *Sale Pending*
Wow no pictures in sig? F*cking gay.[/FONT]
KillerZJ is offline   Reply With Quote Quick reply to this message
Unread 05-06-2003, 10:22 AM   #11
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
No, you can't run a 2 BB and 33s with no problems. If you could, I'd be doing it.
The 33s will fit inside the wheel wells but, you can't turn and you can't flex.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
