Superior C-Clip Dana 44 Rear axles for a44 98 zj 5.9 - JeepForum.com
post #1 of 16 Old 07-14-2011, 11:48 AM Thread Starter
divco13
Anybody use a set of these for replacement, for a low cost replacement ?
http://www.jeep4x4center.com/superio...de-pa5226.html
Bob
http://oldcarandtruckpictures.com/Divco/BobPatterson/
http://www.facebook.com/pages/Divco-Milk-Truck/102362503162366
divco13 is offline
post #2 of 16 Old 07-14-2011, 03:24 PM
JeepFreak1982
Id look deeper into that. The TJ 44 and the ZJ/WJ 44A are very different axles. Not to mentiont he WJ isnt even the same lug pattern.
JeepFreak1982 is offline
post #3 of 16 Old 07-14-2011, 04:07 PM
CatSplat
1994 ZJ
PA5225 and PA5226 are Superior's replacement axle shafts for the ZJ, it says '96-'99 but the '99 part is most likely a typo as their WJ/WK axle shafts (PA5221 and PA5222) are listed as fitting '99-'07. I'd call and double-check first to be safe, but I don't see that being a problem. $120 is solid price for a good set of axles.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #4 of 16 Old 07-14-2011, 04:33 PM
JeepFreak1982
Thats probably $120 each shaft but still $240 for a set of shafts is great.
post #5 of 16 Old 07-14-2011, 04:42 PM
CatSplat
1994 ZJ
Yeah, whoops, meant to type $240 for the pair. They're $150 each from Superior, so saving $60 on the pair is a solid deal indeed. Makes me wonder what their shipping prices are to Canada... my only wonder is whether the axles come with the ABS tone rings.
The Jeep of Theseus
CatSplat is offline
post #6 of 16 Old 07-14-2011, 04:46 PM
JeepFreak1982
6.0L ZJ? Do tell
post #7 of 16 Old 07-14-2011, 04:48 PM
CatSplat
1994 ZJ
Ah, just a bored-out 5.9L, nothing too special I'm afraid.
The Jeep of Theseus
CatSplat is offline
post #8 of 16 Old 07-14-2011, 04:52 PM
JeepFreak1982
You do the 5.9 swap? The 5.9 was only used in the 98 ZJ Yours would have been a 5.2 stock.
post #9 of 16 Old 07-14-2011, 05:01 PM
CatSplat
1994 ZJ
Yup, cracked a piston in the 5.2, was going to rebuild it but found a 5.9L block locally so I built that instead. I've got a D44A out of a 5.9L ready to go in with the lift kit, hence my interest in the axle shafts.
I checked with Superior and the axle shafts do not come with ABS tone rings, but you can swap the tone rings from the old axles to the Superiors.
The Jeep of Theseus
CatSplat is offline
post #10 of 16 Old 07-14-2011, 05:06 PM
JeepFreak1982
Keep in mind the 44A from the 5.9 is a 3.73 ratio. Make sure your OEM front axle is 3.73 also. The ZJ came with 3.55 with out tow package and 3.73 with tow package.
post #11 of 16 Old 07-14-2011, 05:13 PM Thread Starter
divco13
DANA 44HD AXLES
RH 29 3/8
LH 30 3/8
MORRIS Jeep has them for $121.00 each, Plus shipping
http://www.jeep4x4center.com/superior-c-clip-dana-44-rear-left-hand-side-pa5226.html
From Superior Website
Part #PA5225
PA5225 REAR AXLE SHAFT; D44HD, 96-98 Jeep ZJ Cherokee D44HD
Superior axle shaft PA5225 is manufactured to fit 1996 to 1998 Jeep Grand Cherokee. This premium rear axle shaft is 30 3/8" in length and fits the Left Hand side. Please reference axle shaft PA5226 for the corresponding Right Hand axle shaft.
Part #PA5226
PA5226 REAR AXLE SHAFT; D44HD, 96-98 Jeep Grand Cherokee
Superior Axle shaft PA5226 is manufactured to exacting standards to fit 1996 to 1998 Jeep Grand Cherokee vehicles. This premium axle shaft is 29.26 inches in length and fits the Right Hand side. Please reference part PA5225 for corresponding Left Hand side axle ...
Bob
divco13 is offline
post #12 of 16 Old 07-14-2011, 11:10 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
All v8s came with 3.73's except for some very, very rare early '93's.
ratmonkey is offline
post #13 of 16 Old 07-15-2011, 11:45 AM
CatSplat
1994 ZJ
Yep, definitely have the 3.73s in my diffs, just need a conversion U-joint for the larger yoke and it should bolt right in. Whether I'll need to shorten the driveshaft, or if a 4.5" lift will negate the need for that, is the only thing I'm iffy on. Cross that bridge when I come to it, I suppose.
The Jeep of Theseus
CatSplat is offline
post #14 of 16 Old 07-15-2011, 06:51 PM Thread Starter
divco13
Here is a set of ZJ axles, on Amazon.
Alloy Axles, part #12202 Axle Kit
Click on the Amazon logo, for link.
http://www.amazon.com/Alloy-USA-12202-Axle-Kit/dp/B0025TOTP6/ref=wl_it_dp_o?ie=UTF8&coliid=I18FWWLO7B0PVA&colid=DZUUQMAD8OD
$322.00 Deleivered Free shipping
Bob
divco13 is offline
post #15 of 16 Old 07-15-2011, 08:37 PM
JeepFreak1982
Or you could pay $277 shipped for the pair from the link posted above
Need Help locating a part number for rear bumper clip. 08WKJGC WK Grand Cherokee & XK Commander Forum 2 11-13-2009 01:30 PM
Rear wiper clip Skillet ZJ Grand Cherokee Forum 7 06-02-2009 11:06 AM
dana 30 axles jgclorado ZJ Grand Cherokee Forum 12 04-11-2009 08:30 PM
WJ 03 Dana 35 Axles tsconver ZJ Grand Cherokee Forum 7 06-11-2008 07:01 PM
Superior 35 kit/Dana 44a deathbylaxitive ZJ Grand Cherokee Forum 46 08-22-2007 09:10 PM
