Superior 35 kit/Dana 44a - JeepForum.com
post #1 of 47 Old 08-19-2007, 08:42 PM Thread Starter
deathbylaxitive
Just a feeler see what all of your opinions are because i want to do something. But the aluminum has me a little on edge but just gimme pros and cons of each. thanks guys
2004 WJ 4.0/ 3.5" Rocky Road Lift/ 32-11.5-15 Super Swampers/ KMA Wincher/ NEWLY FINISHED Custom Rock Rails(Made by me)/Zacatal Roof Rack
deathbylaxitive is offline
post #2 of 47 Old 08-19-2007, 10:04 PM
FortCollinsZJ
8.8! I have been thinking about the whole 44a VS. 35 kit idea for a long time.... I think that the best bet is to get an 8.8 axle.. It is alot cheaper than the superior 35 kit... unless you plan on getting the 8.8 locked right away. Thats my $0.02
FortCollinsZJ is offline
post #3 of 47 Old 08-19-2007, 10:36 PM
scubatch2
Why would you go through all the trouble putting in an 8.8 and not locking it?I think it depends on your wallet and driving habits, and your set up..if moneys not a problem go w/the 8.8 .
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
scubatch2 is offline
post #4 of 47 Old 08-19-2007, 11:07 PM
MotoX5874
http://www.jeepforum.com/forum/f310/d35-d44a-axle-swap-446226/
Brian
// 5.2 // 4.5" iro // 33" baja claws
MotoX5874 is offline
post #5 of 47 Old 08-20-2007, 12:23 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
get an 8.8
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #6 of 47 Old 08-20-2007, 02:07 AM
FortCollinsZJ
sorry about stealing the thread.. but how hard is it to connect new brakes? how would you cut off the d35 brackets? does the driveshaft need to be shortened to acomodate a bigger diff? any driveshaft changes?
post #7 of 47 Old 08-20-2007, 07:55 AM
sandman
if you are going to go through all the trouble of replacing the axel just get a real D44. its easy to find used!
1993 Jeep ZJ. 4.0
sandman is offline
post #8 of 47 Old 08-20-2007, 08:11 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Is this for your WJ?
If so, I don't think there is a Super 35 kit available.
Wheelin98TJ is offline
post #9 of 47 Old 08-20-2007, 12:51 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
There is no super 35 for a WJ and it is near impossible to get a 8.8 to work well in a WJ. You guys suck at making axle sugestions.
The 44a is a nice upgrade from the D35 for a WJ owner. You keep forctory ABS and speedo reading. Unless you are going to run 37's or bigger you don't have anything to worry about on the 44a.
2013 FR-S
BlaineWasHere is offline
post #10 of 47 Old 08-20-2007, 01:05 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
FTCollinsZJ,
for someone who just lifted their jeep, you sure are making some odd statements. I've run the 35 and super 35 with 33s and now with 35s. Mine hasn't broken.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #11 of 47 Old 08-20-2007, 02:10 PM
Ds4x4
Ds4x4's Avatar
if you go with the 44a you only have one option for a locker which is the Aussie and you will need the open carrier.. also you could truss the 44a to keep the tubes from spinning..
everyone that has an Aussie loves it, even nickerdoodle who seems to have problems with everything he puts on..
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline
post #12 of 47 Old 08-20-2007, 02:11 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
why dosent 8.8 work in WJ??
build thread:
5.9 ANDY is offline
post #13 of 47 Old 08-20-2007, 02:23 PM
BlaineWasHere
BecauseRacecar
Not to meanton custom brakets, becuase you would have to do that in a ZJ also...
Not WJ ABS Compatable. (no ABS)
Not WJ Speedo reading compatable (No speedo/odometer)
Not wide enough... the 8.8 is about 58.5" wide and WJ axels are 63"
Not correct bolt pattern. (8.8 is 5on4.5 and WJ is 5on5)
enough reasons why?
2013 FR-S
post #14 of 47 Old 08-20-2007, 02:32 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
do u actualy want ABS??
and the spedo senso is in the T-case....not the axle...at least in my ZJ and every other jeep i looked at.
i under stand ur reasons and they are good ones....under those conditions, i would proably not do an 8.8 in WJ.
build thread:
5.9 ANDY is offline
post #15 of 47 Old 08-20-2007, 02:33 PM
Colorado 5.9
Colorado 5.9's Avatar
Ah, but the last to steps are fixed with one shot. Spacers!
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
Dana 44 vs Dana 44HD vs Ford 8.8 pic BradMB2004 WJ Grand Cherokee Forum 23 10-01-2011 03:42 PM
dana 30 & dana 44A regearing to 4.10 - your recomendation please. genislav ronen ZJ Grand Cherokee Forum 12 05-14-2009 12:14 PM
What brand Tube seals. ALLOY PERFORMANCE or SUPERIOR? bjl95mustang ZJ Grand Cherokee Forum 1 01-19-2008 12:28 AM
Superior Axle for D35 WJ Eshindi ZJ Grand Cherokee Forum 12 01-17-2008 09:53 AM
Dana 50TTB / Dana 60 Rear Questions Wulfman ZJ Grand Cherokee Forum 2 08-26-2006 08:40 AM
