Supercharged 99 4.7 WJ?? - Page 2 - JeepForum.com
post #16 of 23 Old 10-03-2009, 06:25 PM
WiCkeDuDe
Originally Posted by the88thpianoman View Post
It needs premium because of the upgrade internals being designed to run on it. But with the stock 4.7 computer, you don't have the feature in the HO computer that detects the usage of lower octane gas to retard the timing. It uses multiple knock sensors that don't exist on the regular 4.7 and thus there is no input on the computer. So you just have to default to premium gas.
Saw this info on wjjeeps just now.
So if the HO could be run on pump on non premium gas I still dont see why it matters. If it is to prevent detonation again I dont see how it could matter as the compression ratio is lower. The PCM isnt trying to advance the timing either if no changes are made to it.
Anyone done this swap?
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #17 of 23 Old 10-03-2009, 07:07 PM Thread Starter
488TJ
^ sorry thought it was just speedfreaks.net and it didnt work ill take a look
do u have a build thread rm2001wj
488TJ is offline
post #18 of 23 Old 10-03-2009, 07:42 PM
the88thpianoman
2003 WJ
I could be wrong, but I think it relates to the cam and the timing. Normally it is slightly advanced and defaults to requiring premium, but the knock sensors on the HO allow you to run regular.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #19 of 23 Old 10-04-2009, 09:07 AM
vansskaterfreek
chrysler had no issues with their 4.7's or 2.7's its the owners fault 99% of the time.... either not changing the oil and building up sludge ( 2.7, 3.7, 4,7, and even the 5.7) or overheating it by letting their water pump leak forever.. they are good motors, its just the owners fault for not taking care of it
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #20 of 23 Old 10-04-2009, 09:23 AM
JrMechanic
I'll agree with you on the V8's, but fact of the matter is the 3.7 WAS a POS.
Back on topic, you're probably best checking out a Dodge Forum for info on supercharging a 4.7. I know of several cammed and blown 4.7L Rams and Dakotas.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #21 of 23 Old 10-05-2009, 01:51 AM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
I, too, am thinking about doing the H/O swap on my 01, but was told different storys by different people. i have a superchips tuner, and was thinking about finding a junkyard donor and pulling the heads off the H/O motor concidering the cams are on national backorder.
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #22 of 23 Old 10-05-2009, 02:58 AM
kentman
kentman's Avatar
2006 XK Commander
The 4.7L is a good motor. It is no worse than any other.
I would not supercharge. The 4.7L is plenty good for the platform. This is coming from someone with a supercharged MX-5 sitting in the garage. Have you hit any situations where the 4.7L is not enough? You are just begging for reliability issues if you modify the motor. Enjoy your ride for what it is, and save that money for your next purchase.
If you must spend money, you would be better served doing wheels and lift. Save the forced induction for RWD track cars with manual transmissions.
'06 XK Limited, 5.7L, QD II, Black, 170K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 130K
kentman is offline
post #23 of 23 Old 10-05-2009, 06:20 AM
CanadianZed-J
Originally Posted by JrMechanic View Post
...probably best checking out a Dodge Forum for info on supercharging a 4.7. I know of several cammed and blown 4.7L Rams and Dakotas.
That's what I was going to suggest. Get on the Ram and Dakota forums. We all use the 4.7 but I'd imagine here at JF we're more interested in offroad ability than street performance (which is why we still drool over Jeeps with $50,000 of upgrades running a bone stock engine).
Yes, I'm also a believer in the 4.7, however, it's no different from any other engine in that when you make it push more power you're going to lose some reliability.
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
Supercharged 4.7 mferraro76 ZJ Grand Cherokee Forum 10 10-17-2006 05:36 PM
Blond w/ a supercharged 5.9L 93 ZJ Limited jeep_on ZJ Grand Cherokee Forum 7 08-13-2006 06:52 AM
supercharged grand cherokee? 4X4Cherokee ZJ Grand Cherokee Forum 5 01-09-2005 07:09 PM
