super low MPG problem - JeepForum.com
post #1 of 6 Old 03-11-2003, 01:46 PM Thread Starter
dazhi888
10 MPG local
12 MPG Highway
8.0 MPG life time average
I own a 93 GC I6 4.0, 152,000 Mile for 6 month.
6 month ago I replace new catalytic converter and distributor cape, I did engine flush, I changed 3 Gear box fluid.
I change oil and clean fuel injector every 3 month.
I change air filter last month.
I check oil and tire pressure every week.
The engine noise is normal. Engine idle speed is about 600.
But the MPG still very low, 20 gallons only run 200 Mile
What I should do? replace spark plugs or O2 sensors?
What's the MPG of your 93 GC I6?
dazhi888 is offline
post #2 of 6 Old 03-11-2003, 02:06 PM
scubatch2
Good god .I only get an average of 11mpg,but thats on a 5.2.I thought a 6 would be atleast 15-17.Are you really hard on the gas.good luck. p.s you might want to have a shop run it on the computer to see what code's pop up.
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
scubatch2 is offline
post #3 of 6 Old 03-11-2003, 06:22 PM
KillerZJ
KillerZJ's Avatar
from what i have read and heard, the I6 gets worse than the V8, but the I6 would have a hard time getting 17 mpg...i would love it. i have a I6 and the mpg is crappy, but 10? theres got to be something...
Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only.
*Sale Pending*
Wow no pictures in sig? F*cking gay.
KillerZJ is offline
post #4 of 6 Old 03-11-2003, 07:18 PM
Intrepidjeep
Intrepidjeep's Avatar
How does that math work out, by the way? 10 local, 12 highway, 8 average???
Anyway, mine gets 20-21 highway, 16.x around town. Maybe 15.x if it was heavy stop-and-go all week, especially a lot of idling.
If you do a lot of idling the mileage will drop fast. A heavy foot will also give you poor mileage.
The six (normal healthy ones with normal healthy mpg) gives better fuel economy than the V8 but only by 1 or 2 mpg.
-- Marcus
Cape Canaveral, Florida
2005 Jeep Grand Cherokee Laredo 4.7L
2005 Dodge Durango SLT 4.7L
Intrepidjeep is offline
post #5 of 6 Old 03-13-2003, 01:23 AM
Slightly_Off
the gas isue is why my GC is now for sale, 11 mpg to school and work is not working out, bye bye heep of a jeep, hello subaru? And insureance is a bit high for me on the GC.
Slightly_Off is offline
post #6 of 6 Old 03-13-2003, 06:23 PM
demtjcj
i have a 93 GC limited with full time 4wd and i am averaging 17.1 mpg. it has that option where it tells me the mpg. this is mostly city. change your plugs, wires, fuel filter. this will help.
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
Super annoying door sensor problem... HELP! ixl4 WK Grand Cherokee & XK Commander Forum 0 08-13-2009 04:46 PM
Super 30 and Super 35 Kits shadetree ZJ Grand Cherokee Forum 11 02-13-2007 08:53 PM
super ride or super flex? TheAngus ZJ Grand Cherokee Forum 23 07-27-2006 02:09 AM
Stating a real diff between super-ride and super-flex rossj711 ZJ Grand Cherokee Forum 3 03-07-2005 07:48 PM
Super 35 kit bluYJ ZJ Grand Cherokee Forum 1 05-05-2003 12:16 PM
