Sunroof sensor - JeepForum.com
post #1 of 5 Old 12-29-2012, 11:19 AM Thread Starter
Kingr98
Sunroof sensor
What is the small sensor on the side of my sunroof track supposed to do? It appears to be at a position to make the window stop at the full closed position between sliding back and popping up.
I have disconnected it and can't tell any difference. Is this something that can be repaired/replaced without getting an entire new sunroof?
Kingr98 is offline
post #2 of 5 Old 01-04-2013, 05:58 AM Thread Starter
Kingr98
OK. I will try this a different way.
From inside the Jeep, how do you know when the sunroof is fully closed? I have only had it working for a few days, and so far I have checked from the outside and tweaked it back and forth until it was closed and level with the roofline.
Kingr98 is offline
post #3 of 5 Old 01-04-2013, 06:23 AM
congerz83
If it's level with the roof-line, you should be good... Check for leaks, and make sure it isn't due to bad weatherstripping...
congerz83 is offline
post #4 of 5 Old 01-04-2013, 07:38 AM
Donnyd21
Pretty sure its the switch that stops the motor when the sunroof comes down from the "vent" position
Donnyd21 is offline
post #5 of 5 Old 01-04-2013, 09:57 PM Thread Starter
Kingr98
Based on where its at, that was my guess. That would also tell me when the sunroof is fully closed...if it worked.
Kingr98 is offline
sensor , sunroof
