Suggestions on Spark Plug, Distributor Cap Brands? - JeepForum.com
post #1 of 22 Old 08-15-2017, 08:46 PM Thread Starter
BrentM94
I'm going to put on new Spark Plugs, Spark Plug Wires, and a new Distributor Cap. I'm looking on Rock Auto. I mainly need advice for the spark plug brand/type that you would recommend from rock auto I was going to go with any decent looking distributor cap and wires.
I heard that you want spark plugs that remain closest to OEM. Any suggestions or advice, thank you!
BrentM94 is offline
post #2 of 22 Old 08-15-2017, 08:55 PM
PolkaPower
NGK coppers for plugs. Some 8mm wires would be nice. Brass cap and rotor.
I have the Airtex/Wells cap sitting on my shelf. It's nice. Also Summit 8mm wires. Look like good quality.
I'm currently using ACCEL wires, cap/rotor, and plugs though. Accidental order I couldn't cancel.
PolkaPower is online now
post #3 of 22 Old 08-15-2017, 08:57 PM
Uniblurb
Uniblurb's Avatar
Champion copper plugs are OE and the ones I've always used in my 96 4.0. Not sure what Rockauto is selling but below are the tune-up parts I've used. Prices are probably a little higher since that post is from 4 years ago. Good luck.
http://www.jeepforum.com/forum/f13/s.../#post15809984
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #4 of 22 Old 08-15-2017, 09:09 PM
zjosh93
Just bought NGK coppers for mine. I'd been using Champion copper but I hate how crappy their production tolerances are on the side electrodes.
zjosh93 is offline
post #5 of 22 Old 08-15-2017, 10:03 PM Thread Starter
BrentM94
I'm thinking about purchasing:
ACDELCO Spark Plug Wires $16.71
NGK Copper Spark Plugs (6 of them at $1.39 a piece)
AIRTEX/WELLS Distributor Cap + Rotor $26.79 (Should I hold off on buying the Cap and Rotor and just spend the money on whole new distributor?)
Is it wise to buy the Rotor with the Cap? Do you think I should replace the stock Distributor in general? Might save money purchasing the Distributor that comes with the Cap and Rotor for $47.79.
I'm trying to spend money where it's needed though, for example I have other important things to spend money on (Jeep Wise) so perhaps wait on the new Distributor and stick with the Spark Plugs, Wires, Cap and Rotor?
BrentM94 is offline
post #6 of 22 Old 08-15-2017, 10:48 PM
PolkaPower
You don't want to replace the distributor. It's not necessary and If you don't know what you are doing you can really screw things up.
It's the difference between tying your shoes or performing surgery.
Just replace the cap and rotor. They both come together.
post #7 of 22 Old 08-15-2017, 10:52 PM
Uniblurb
Uniblurb's Avatar
While you wouldn't think those Denso plug wires aren't that good since they're only $11.38 but they work fine. And I'd buy them before buying AC Delco plug wires since their brand has had some problems with electrical parts in general.
Not sure about the Airtex/Wells cap w/rotor and you best hope they work better than the Airtex fuel pumps & sending units which are known to fail. Could be ok but just not familiar w/anybody using one.
No sense if getting a distributor because you get a cap w/rotor. The caps are all aluminum contact ones on all those distributors and you want a brass contact cap. When I bought a new distributor I threw the aluminum contact cap away.
Uniblurb is offline
post #8 of 22 Old 08-15-2017, 10:56 PM
PolkaPower
Here's the airtex. Looks good enough, I'd run it.
post #9 of 22 Old 08-15-2017, 11:01 PM
PolkaPower
Here's the Accel rotor and the Accel wires.
The red Summit wires looks nice too.
ForumRunner_20170815_220020.jpg   ForumRunner_20170815_220030.jpg   ForumRunner_20170815_220040.jpg   ForumRunner_20170815_220048.jpg
post #10 of 22 Old 08-15-2017, 11:27 PM Thread Starter
BrentM94
Okay I'm going with the Denso wires. The NGK Copper Spark Plugs. Still not sure about the Distributor Cap the only one with Brass contact on Rock Auto is the Airtex/Wells one. (I'm willing to shop elsewhere but trying to keep the quality good but the price reasonable.)
Would you guys recommend a platinum spark plug?
BrentM94 is offline
post #11 of 22 Old 08-15-2017, 11:28 PM
PolkaPower
No platinum plugs.
post #12 of 22 Old 08-15-2017, 11:29 PM Thread Starter
BrentM94
Originally Posted by PolkaPower View Post
No platinum plugs.
Okay, I'm happy I posted here then. Thank you!
BrentM94 is offline
post #13 of 22 Old 08-15-2017, 11:32 PM
PolkaPower
Definitely get a brass cap and rotor.
post #14 of 22 Old 08-15-2017, 11:33 PM Thread Starter
BrentM94
Those wires look nice, but not really wanting to pay that much for wires. So we can agree on the Airtex/Wells brass contacts for $26.79? With Rotor included. Thanks for the advice on the Distributor I didn't know it could be dangerous/ difficult to install. I've never installed a Distributor before so I'll dodge that bullet so I don't make things worse.
BrentM94 is offline
post #15 of 22 Old 08-15-2017, 11:50 PM
PolkaPower
Yeah, you don't want to mess with it unless you have to.
You'll be fine with the stuff you chose.
