Suddenly not starting as it was!!! - JeepForum.com
post #1 of 6 Old 03-11-2004, 02:43 PM Thread Starter
Levi_264
I have a 97 two door cherokee sport and it is has recently decided not to start right up as it did before. It used to fire up as soon as i would turn the key but it now rolls over a bunch of times before starting.
If anyone has any idea of what might be wrong please let me know thank you very much.
Levi_264 is offline
post #2 of 6 Old 03-11-2004, 05:32 PM
Meerkat
Weak spark. Check cap, rotor, wires and plugs.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 6 Old 03-12-2004, 01:08 AM
94ZZJJ
That is kinda vauge in description. Does it turn as fast or not? If not could be the battery or starter going. It it turns ok probably what was said above. My started turned over slow because the starter got soaked with the oil leak(s) and it died shortly after.
94ZZJJ is offline
post #4 of 6 Old 03-12-2004, 07:30 AM
deeger
deeger's Avatar
It sounds like a weak battery. Some Jeep models, especially ZJs, have a reputation of resetting the computer when it detects a low battery condition, which results in poor starting, or stalling.
Deeger
If it ain't broke...fiddle with it 'til it is
'94 ZJ Black 5.2 V8, AMRacing Wheels, BFGs, 160K miles
'95 BMW 525i stock
'97 Honda CBR900RR Erion Racing Edition
deeger is offline
post #5 of 6 Old 03-15-2004, 06:18 PM
Bicycleman
I have a 98' GC, The starter went at 74,000 miles with no warning at all.
Bicycleman is offline
post #6 of 6 Old 04-03-2004, 03:28 PM
jaime goodhart
2000 WK
check your fuel pressure on the fuel rail. it could be dropping after sitting awhile. could be either the fuel regulator or the sending unit in the gas tank (bad check valve or loose hose). you should be able to maintain about 10 -20 pounds at the fuel rail.
jaime goodhart is offline
4.0l zj running hot suddenly... leofanti ZJ Grand Cherokee Forum 5 01-13-2010 09:04 PM
VIC suddenly broken mudlover1832 ZJ Grand Cherokee Forum 12 07-28-2007 07:46 PM
Jeep suddenly stops once I get to about 18 mph bonnie_michelle ZJ Grand Cherokee Forum 10 06-05-2007 10:25 AM
Wipers Suddenly Stopped Help Please anthracite93 ZJ Grand Cherokee Forum 12 03-24-2007 10:31 PM
'96 GC dies suddenly d.w. ZJ Grand Cherokee Forum 45 08-23-2006 09:20 PM
