Sub - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Sub
Engo winch sale-- Best deal you will find. and FREE SHIPPIFree Air Compressor with Purchase of ARB air lockerIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-29-2009, 04:26 PM   #1
Timothy_90
Timothy_90's Avatar
Sub
So, I know a few of you have done this. Can I see pictures of anyone that has built a subwoofer box to fit in that little cargo compartment in the back right corner of the cargo area? I'm considering getting a subwoofer but I don't want to sacrifice all the cargo space in the back. I'm not looking to make some crazy "bumpin'" "system", I just want to add a little bass because it gives just about any music some good depth and fuller sound. So it would be like one 8 or maybe a 10 if it'll fit. Also, show where you put the amp, I'm thinking I would put it under the back seat but I'm not sure.
Timothy_90 is offline   Reply With Quote
Unread 12-29-2009, 04:30 PM   #2
Ski01xj
Try the picture request forum. Might get a little bit more feedback.
Ski01xj is offline   Reply With Quote
Unread 12-29-2009, 04:40 PM   #3
UltimatE
Resident Audio Guru
UltimatE's Avatar
There have been a few guys who have done this, including some with XJ's (Same idea) You'll have to most likely do a full custom job with fiberglass to get the best results. A shallow mount 10" would likely be your best bet.
Under the rear seat is a great place for the amp, that is where I have my 4-chan. Out of sight and easy to run wires there.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Unread 12-29-2009, 05:05 PM   #4
Timothy_90
Timothy_90's Avatar
I was thinking I could make the box out of wood, but would it not work as well? I've never messed with fiberglass before.
Unread 12-29-2009, 06:09 PM   #5
WJChris
Problem is there isn't much room to fit a square box, or one that is semi-contoured. If you were to make one with fiberglass, you could make it more form fitting and optimize the space, "tucking it away" and therefore keeping all your precious cargo room.
WJChris is offline   Reply With Quote
Unread 12-29-2009, 07:40 PM   #6
Timothy_90
Timothy_90's Avatar
Good point, guess I'm going to have to learn how to make stuff out of fiberglass
Unread 12-29-2009, 08:55 PM   #7
blackjack12982
1994 ZJ
Search member SirFuego, I seem to remember a writeup he did about putting a sub/amp in the seat back of the backseat. It seemed to work very well, and looked very clean.
Robert
1994 ZJ Limited Edition - 5.2L, 46RH, NP 249 -> NP231, Mopar Performance PCM, HP30, F>R w/ 2" BB, 35" KM2's, KOR rad support, Homemade winch bumper, Cherry Bomb glass pack, custom rock sliders, skids galore, homemade roof rack, 6 Hella 500's, and Taurus e-fan.
1947 CJ2A - All original, and gonna stay that way.
Want to do an Aurora reverse light swap? Need a 231/242 bezel? Need a Taurus efan?
http://www.jeepforum.com/forum/f130/...s-fan-1497489/
http://www.woundedwarriorproject.org/
blackjack12982 is offline   Reply With Quote
Unread 12-29-2009, 09:01 PM   #8
madZJ
I got a box from Q-Customs (Crutchfield has them for $250 in several colors) it holds one 10" sub. Sounds awesome, amp sits under the rear seat in factory location (Alpine 5 channel).
madZJ is offline   Reply With Quote
Unread 12-29-2009, 09:40 PM   #9
footinmouth47
I had one there but blew the amp(it was a remand jbl) I dont even have a pic of it. after learning how to fiberglass and practicing on some other stuff I modded a 5.9 sound bar to house two 8 inch speakers Im sure you could put subs in it. so this is what it looks like
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline   Reply With Quote
Unread 12-29-2009, 09:44 PM   #10
Kramer H
Built and Supercharged 47
Kramer H's Avatar
i have the JL stealthbox in my WJ, holds one 10" JL. it sounds GREAT.
Built Beater 01 WJ MY BUILD THREAD
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline   Reply With Quote
Unread 12-29-2009, 10:13 PM   #11
spife7980
i just have my amp under the rear passenger seat, plenty of circulation there for it so long as it isnt tall enough/mounted high enough so that it is touching the bottom of the seat.
and dont be afraid of fiberglass, its intimidating only until you start playing with it.
fiberglass forums is a site that had alot of info on it back when i was first learning. and i know there are a couple of writeups on that particular location here.
my glassed box.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline   Reply With Quote
