STUPID SECURITY SYSTEM! How do I disable it PERMANENTLY? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > STUPID SECURITY SYSTEM! How do I disable it PERMANENTLY?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFather's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPI
Unread 10-17-2005, 05:41 PM   #1
coolest_Stan
well, I searched a few threads, all I came up with was this one:
http://www.jeepforum.com/forum/showt...sable+security
I need help COMPLETELY DISABLING my security system.
Tje secuirty system has been drawing power from my battery even while im driving, and as a result, now my battery is dead, so I can't start up my car. I know its the security system, because after I got my car becak from the mechanic, the security light on my dash was always on, even when I was driving.
ALso when I jump start the jeep, the security system goes crazy, and the lgihts start blinking, and there is no way to stop it. I cant do the passenger side door lock then unlock and open and then clsoe door trick either, because I have to keep the keysin the iginition (because once I take the keys out of the ignition the car stops running, and I can't start it again due to the dead battery).
so pelase, is ther any way to premantently disable the stupid security system?
can i cut any wire or soemthing, I just dont even want it anymore!!! please help
thanks
93' Grand Cherokee Limited 4.0 L 190 hp 4x4
235x75 BFG Goodrich A/Ts
K&N Drop In Filter
New Coolant Resevoir Cap
Current Projects:
coolest_Stan is offline   Reply With Quote
Unread 10-17-2005, 05:43 PM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
So was I right that it was the battery?
ArloGuthroJeep is offline   Reply With Quote
Unread 10-17-2005, 05:46 PM   #3
coolest_Stan
ummm yes arloguthrojeep you are a genius
i took it to autozone, and since the security woudl go crazy (as I mentioned in my post above)
, the security system would draw anywhere from 13-15 volts (because of the flashing lights, I assume). SO the autozone guy thought the altnerator was going crazy. But i insisted on waiting until the lights stopped flashing adn for the secuirty system to automatically disable, and then he checked the alternator again, and it was working fine.
So thanks arloguthrojeep for your wise words!!! you saved the day!! HOORAY
I still need to know how to disable the security though.
woudl this work:
Underneath drivers side rear seat there is a wiring harness with a purple wire and yellow tracer. You need to tap into that wire with a wire that is connected to ground. This will disable your factory alarm. I just recently did this on mine. Be careful to use the purple with yellow tracer and Not the purple with white tracer!
I dont know where a ground wire is that I can connect the purple yellow tracer wire to though....
K&N Drop In Filter
Current Projects:
Unread 10-17-2005, 05:49 PM   #4
RAAB3485
Viewer Discretion Advised
RAAB3485's Avatar
I don't know how to disable your security system. But I do know that if you can't find a ground all you have to do is take a piece of wire with a round connector on the end, screw it to metal somewhere with a self tapping screw and viola, you have a ground.
Eric
Colorado Jeep Club Member #1
RAAB3485 is offline   Reply With Quote
Unread 10-17-2005, 08:04 PM   #5
coolest_Stan
ok cool, im going to try to do this
i hope i dont disable anythign important like my abs brakes or anything
K&N Drop In Filter
Current Projects:
Unread 10-17-2005, 08:07 PM   #6
RAAB3485
RAAB3485's Avatar
And I hope you don't start your Jeep on fire by grounding a wire that should not be grounded. If it starts to arc, pull it away before it welds itself to your Jeep.
Eric
Unread 10-17-2005, 08:11 PM   #7
coolest_Stan
ok. Ill update you soon. one quick question also:
alright.....
I got a duralast red top right now, probably not as agood as an optima
BUTTT
OK, DO i need a new battery?
my battery jstu got drained dead by my security system, so my jeep wont start anymore. Can I just recharge the battery (the guy at autozone said he could recharge it, it would take like an hour or so)
Or do I need a new battery? right now the battery does not work at all if I try to start up my car. no electricity at all.
K&N Drop In Filter
Current Projects:
Unread 10-17-2005, 08:15 PM   #8
RAAB3485
RAAB3485's Avatar
alright.....
BUTTT
I just gave you a reply to this same posting in your other thread.
Eric
Unread 10-17-2005, 08:18 PM   #9
Slamm36
hey , let me know if grounding out that wire works right now on my mom GC she cand us the keyless entry with out setting off the alarm
-Wyatt
[COLOR=DarkGreen]1996 Laredo 4x4 I6 177800 Miles - Slightly Modified[/COLOR]
[COLOR=Red]Optima RedTop[/COLOR] | BFG T/A KO's 30x950 | [COLOR="Red"]22" Cherry Bomb[/COLOR]
[COLOR="DarkOliveGreen"]KOR Crossmemeber [/COLOR] | V8 UpCountry Springs | [COLOR="Sienna"]Dayton Timberline MT 31x1050[/COLOR]
[COLOR="DarkRed"]K&N Drop-In [/COLOR] | Homemade QD's | [COLOR="Red"]KOR Radiator Support[/COLOR]
Slamm36 is offline   Reply With Quote
Unread 10-17-2005, 08:22 PM   #10
coolest_Stan
ok , im having trouble finding it though, I dont know if maybe it was intended for a different model jeep?
K&N Drop In Filter
Current Projects:
Unread 10-17-2005, 08:31 PM   #11
RAAB3485
RAAB3485's Avatar
I wish I was at work right now, I would be able to help you. I work at BestBuy installing car audio, car alarms etc. and we have a "forum" type thing where other BestBuy installers post tips on certain vehicles. Also, we have access to diagrams that tell us what color wire does what for any vehicle. All we do, is type in the make and model and it tells us what wire does what. Since we install car alarms, I would be able to tell you what wire does what for the stock alarm.
Eric
Unread 10-17-2005, 08:32 PM   #12
RAAB3485
RAAB3485's Avatar
Wow, I can't beleive what I said in the first line of my last post:
I should be slapped for saying such a thing.
Eric
Unread 10-17-2005, 08:36 PM   #13
coolest_Stan
lol
well I would really appreciate it if you would help me find it for a jeep grand cherokee limtied edition 93, to disable the stock alarm system
I cant seem to acess under my driver's side rear seat right now
THANKS!!
K&N Drop In Filter
Current Projects:
Unread 10-17-2005, 08:42 PM   #14
Woody
Retired back to Bowties
Woody's Avatar
1985
Stan the wire you are looking for should be in the drivers door panel near the lock switch.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Unread 10-17-2005, 08:45 PM   #15
coolest_Stan
really? ok, purple wire and yellow tracer?
that would be a lot easier, I ve taken my door panel off so many times. airmanwoody, any idea hwere to groudn it though?
K&N Drop In Filter
Current Projects:
