stumbling idle after warmed up - Page 3 - JeepForum.com
post #31 of 36 Old 08-24-2013, 02:14 PM
ZeeJay1997
Originally Posted by JaneLee View Post
remove the o2 sensor
if you havent disconnected the o2 sensor, nevermind about checking the ignition system. the object is to get it out of the sensor circuit to make the PCM use default fuel strategy.
ZeeJay1997 is offline
post #32 of 36 Old 08-25-2013, 08:47 AM Thread Starter
JaneLee
1994 ZJ
i previously disconnected the o2 sensor with no issues found before i unscrewed it to test the CAT. It threw codes for every injector. I did look at the ignition coil and guess what? It does have a large crack in it. It does get very hot when the engine warms up and starts it's tricks. Problem found? previously had a buddy look at it and he missed it, now he thinks that's probably the problem?
JaneLee is offline
post #33 of 36 Old 08-25-2013, 08:50 AM
ZeeJay1997
Problem found?
Yes, that would be reason for replacement. Whether or not it is your only problem, on the ZJ will divulge those secrets.
post #34 of 36 Old 08-25-2013, 08:56 AM Thread Starter
JaneLee
1994 ZJ
ok lol Will see then thanks
JaneLee is offline
post #35 of 36 Old 08-29-2013, 09:19 PM
wwilly1968
ok
wwilly1968 is offline
post #36 of 36 Old 08-29-2013, 09:28 PM Thread Starter
JaneLee
1994 ZJ
OK guys. replaced the ignition coil, y'all were right. it was cracked motor side and bad. now she's happy. thank you guys so much
JaneLee is offline
