Stuck on tranny gasket(CORK) - JeepForum.com
post #1 of 8 Old 05-07-2009, 10:25 AM Thread Starter
craddock01
Any one know an easy way to remove a REALLY stuck on cork tranny Gasket?
craddock01 is offline
post #2 of 8 Old 05-07-2009, 10:29 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Straight razor scraper?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 8 Old 05-07-2009, 10:30 AM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
to get it off the pan, i used a dremel with a wire wheel. tranny side i used a peice of light grit emory cloth.
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #4 of 8 Old 05-07-2009, 11:08 AM
liquid
I used a putty knife, gasoline, and a little elbow grease. Oh, and some patience and bloddy knuckles if you are not careful
For the gasket portion stuck on the actual pan, I used a wire-wheel on an air compressor.
Karl
'00 WJ I6
liquid is offline
post #5 of 8 Old 05-07-2009, 11:22 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Hunter
Yep, get what you can with the scraper and follow up with die grinder and Roloc disc.
HighLonesome is offline
post #6 of 8 Old 05-07-2009, 01:02 PM Thread Starter
craddock01
Thanks slow going so far nicked the pan with razor,got my thumb once, this is fun.
post #7 of 8 Old 05-08-2009, 07:43 AM
NewGuy321
Get a good sized tupperware container (just big enough to fit the trans. pan in), fill it with boiling water from kettle and let trans. pan soak upside down. Scrub with brass or Nylon brush (something soft). Just had the same problem and this works great. Be carefull not to "Gouge" the pan with razor blades and what not...
NewGuy321 is offline
post #8 of 8 Old 05-08-2009, 02:07 PM
cheapfix
1991 XJ Cherokee
Permatex "Gasket Remover" in blue spray can. Spray it, don't let it drip on your skin as it immediately starts to burn (ask me how I know this), let it soak for 10 min, then scrape off with a razor scraper. Repeat as many times as you need.
I used this stuff on a baked-on cork oil pan gasket, and it took 3 or 4 applications to get it all off the block.
Should work well for the tranny pan as well, but it is very toxic stuff. You don't want any of it in the guts of your tranny, so I would cut out some cardboard and hold it up to the bottom of the tranny to prevent overspray from getting in there. Rubber gloves are nice if you have them.
Recovering moparholic
cheapfix is offline
46re Tranny gasket reusable? leaking ZJcrawler45 ZJ Grand Cherokee Forum 3 09-10-2009 09:54 PM
will the lube locker gasket work for my 42RE tranny? MEinSoCal ZJ Grand Cherokee Forum 0 11-04-2008 01:27 AM
Tranny sump gasket fern30 ZJ Grand Cherokee Forum 3 04-23-2008 06:36 PM
zj tranny stuck in 1st 96xj4x3 ZJ Grand Cherokee Forum 4 09-14-2006 03:11 PM
Cork or RTV? 01grander ZJ Grand Cherokee Forum 2 03-11-2005 06:03 PM
