stuck t-case bolts. - JeepForum.com
post #1 of 8 Old 07-23-2007, 09:52 PM Thread Starter
Derek33
Derek33's Avatar
stuck t-case bolts.
one of my t-case bolts lost its threads.
when i loosen the bolt it just spins and spins, but wont get tighter or looser.
what do you recomend i do to get it out?
Derek33 is offline
post #2 of 8 Old 07-24-2007, 12:36 AM
-Joe-
-Joe-'s Avatar
which bolts? Drain and fill or the ones that hold it to the transmission? <=- these are studs with nuts on them..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 8 Old 07-24-2007, 01:00 AM
jfowlzj95
He could be talking about the ones that hold the case together?
95 zj with some big n heavy crap!
jfowlzj95 is offline
post #4 of 8 Old 07-24-2007, 02:39 AM
Cha Cha
If the bolt did lose it's threads then clamp a set of vise grips on the bolt and pull it out while turning it. Good Luck!!!
Cha Cha is offline
post #5 of 8 Old 07-24-2007, 02:42 AM
Cha Cha
If the bolt did lose it's threads then clamp a set of vise grips on the bolt and pull it out while turning it. Once you have done this check the threads where the bolt goes in to the t-case if needed rethread and get a new bolt.
Cha Cha is offline
post #6 of 8 Old 07-24-2007, 07:53 AM Thread Starter
Derek33
Derek33's Avatar
sorry i wasnt clear.
one of the bolts that holds the cross member to the body of the jeep lost its threads and just spins.
i figured id try to get a crow bar between my body and cross member to apply pressure to the bolt.
Derek33 is offline
post #7 of 8 Old 07-24-2007, 07:57 AM
1BADDROP
try an open end wrench to apply downward pressure on the bolt while you spin it with a ratchet.... good luck!!
1998 ZJ SE I-6 w/ 42RE & 242, D30 & D35 axles 4"+ suspension , Moabs with 33" Bighorns, Borla Header, Magnaflow Muffler
1BADDROP is offline
post #8 of 8 Old 07-24-2007, 02:06 PM
-Joe-
-Joe-'s Avatar
Theres a nut welded inside the frame rail for those.. It probably broke loose..
Same thing happened to me, when chaning my transmission.
I cut a *small* access hole right beside it so i could get a wrench on a new nut and fixed it that way..
- Joe -
-Joe- is offline
Help Stuck Transfer Case!!!! 1997zj ZJ Grand Cherokee Forum 10 07-10-2011 05:55 PM
Hub bolts stuck, can't remove hub to replace cv wpbixler ZJ Grand Cherokee Forum 12 01-03-2010 11:14 PM
transfer case stuck in 4wd? lateralus3 ZJ Grand Cherokee Forum 3 07-18-2009 10:07 PM
'93 ZJ stuck t-case shifter Crispin ZJ Grand Cherokee Forum 7 01-04-2007 03:32 PM
i think my transfer case is stuck S10Eater ZJ Grand Cherokee Forum 6 10-14-2006 01:41 PM
