Stripped my threads... - JeepForum.com
post #1 of 39 Old 06-24-2010, 02:58 PM Thread Starter
soul_Less
1994 ZJ
So I was replacing my top idler pulley since it still gave a bit a chirp. I started to tighten the bolt when all of the sudden there was a crack and the tension on the bolt just let go.. (got myself a good gash on my middle finger against the P/S pulley too)
So heres the hole the bolt is supposed to attach to..
And when I got the bolt out, I found this happened...
I tried putting the bolt back in but it only tightens so far before becoming loose again..
What's the fix for this???
soul_Less is offline
post #2 of 39 Old 06-24-2010, 03:07 PM
ras2001wj
ras2001wj's Avatar
Helicoil?
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #3 of 39 Old 06-24-2010, 03:10 PM Thread Starter
soul_Less
1994 ZJ
whats that?
post #4 of 39 Old 06-24-2010, 03:22 PM
murphydajeep
In the future, that bracket as well as several other component brackets under the hood are made of aluminum, and you never tighting down a bolt in an aluminum socket with a bar...Ive always been told by the greats that you tighten it down as much as you can with your fingers and take a wrench and put it a quarter turn past that...anything more and what happened to you happens.
What you can do is drill and tap it and use a larger bolt, essentially what a helicoil is, is a kind of "replacement" thread for the hole you striped out. But you can also just go to your auto parts store and usually rent a tap and die set and just drill your own threads into the striped hole and like I said, use a larger bolt other than your stock one
murphydajeep is offline
post #5 of 39 Old 06-24-2010, 04:00 PM
-Joe-
-Joe-'s Avatar
Is that not a helicoil that was pulled out? Looks like it was repaired before.
If you can access the rear of the hole (which it looks like you can), just get a longer bolt and use a nut on the other side of the bracket.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #6 of 39 Old 06-24-2010, 04:09 PM
ras2001wj
ras2001wj's Avatar
That honestly does look like a helicoil
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #7 of 39 Old 06-24-2010, 04:26 PM
5-90
5-90's Avatar
1988 XJ Cherokee
It looks like a Heli-Coil, but is not.
A Heli-Coil is wound from diamond-shaped stainless steel wire. Note that the outside of the "coil" that was pulled out is relatively flat - what happened is that the threads were sheared out of the aluminum casting, and pulled with the screw. I've seen this before, and it always looks just like the pictures.
To install a Heli-Coil (or similar Screw Thread Insert,) you'll get a kit with the inserts, a drill bit, tap, and an installation mandrel. Keep these items together! (NB: You can always buy replacement inserts easily. The drill bit is typically a standard size, but not always. The taps are difficult to find.) Drill in nice and straight, then tap (the tap will follow the hole. This is why drilling the hole straight is important.) The coil is wound onto the installation mandrel, then screwed into the hole. Screw the coil down about one thread past flush with the surface, then reach down the hole (long-nose pliers) and snap out the tang at the bottom.
A Heli-Coil is typically considered a "permanent" repair, and I've used them in a variety of locations (including cylinder head screw holes!) with sound results.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #8 of 39 Old 06-24-2010, 04:37 PM Thread Starter
soul_Less
1994 ZJ
its not a through bolt, the lower idler bolt is though.
i dunno, there doesnt look like theres enough room to get a drill in there, but we'll see.
post #9 of 39 Old 06-24-2010, 05:48 PM
-Joe-
-Joe-'s Avatar
I would agree.. But I still see thread in that hole.. It looks like a previous repair to me.. But who knows.
I would drill thru the bracket and use a longer bolt.. I personally wouldnt rely on the helicoil to hold it..
- Joe -
-Joe- is offline
post #10 of 39 Old 06-24-2010, 05:53 PM
murphydajeep
Its definitely sheared thread, ive done it myself
post #11 of 39 Old 06-24-2010, 06:25 PM Thread Starter
soul_Less
1994 ZJ
The back half of the threads came out, thats why I thought I could still torque the bolt with the thread remaining. That obviously didnt work..
The only problem I'd have either turning it into a through-bolt and Heli-coil is that theres like no room between that hole and the rad to get a drill in there..
post #12 of 39 Old 06-24-2010, 06:28 PM
-Joe-
-Joe-'s Avatar
90 degree drill or adapter.
3/8" Close Quarters Drill
- Joe -
-Joe- is offline
post #13 of 39 Old 06-24-2010, 06:35 PM
SILASPRIT
I would just put a nut back there....
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline
post #14 of 39 Old 06-24-2010, 06:54 PM Thread Starter
soul_Less
1994 ZJ
Hmm maybe my friend has a drill like that... And making it a through-bolt means I don't need thread right?
post #15 of 39 Old 06-24-2010, 07:02 PM
SILASPRIT
Right, just a nut on the back.
-SOLD-
Stripped Lug Nuts Marky1 ZJ Grand Cherokee Forum 34 11-08-2008 03:22 PM
Stripped Lug Screw th3godf4th3r ZJ Grand Cherokee Forum 7 04-29-2007 08:14 PM
Stripped lug nuts?? rustycherokee18 ZJ Grand Cherokee Forum 14 02-26-2007 01:06 PM
Help! Stripped lug nut! 7tiger7 ZJ Grand Cherokee Forum 4 01-22-2006 02:50 PM
Stripped threads - What are my options? Radiac ZJ Grand Cherokee Forum 4 01-21-2006 08:22 PM
