Stripped Lug Nuts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Stripped Lug Nuts
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 01-27-2008, 11:42 AM   #1
Marky1
Stripped Lug Nuts
Is there any tool or way to remove a stripped lug nut from being over tightened.(wrench wore down the flat sides of nut,keeps sliding ,getting worse)Looking for something that will grab it to remove it before I get a flat ,and replace it with a new one(s).The other three wheels are fine.
Marky1 is offline   Reply With Quote
Unread 01-27-2008, 11:46 AM   #2
alivenkickin28
if you have an old socket that you can maybe get on it to get it off -- may have to use a hammer to beat it on and then u could get it off...
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
[url]http://s221.photobucket.com/albums/dd197/alivenkickin28/[/url]
alivenkickin28 is offline   Reply With Quote
Unread 01-27-2008, 11:57 AM   #3
95ZJ
yup thats the best way i think to, just hammer on an old socket thats 1 size smaller, 6 point ussually works better to
95 GC limited
-lifted
-locked F+R
-33" tsl's
95ZJ is offline   Reply With Quote
Unread 01-27-2008, 12:06 PM   #4
alivenkickin28
should work fine....i've had to do crap like that before too....
Unread 01-27-2008, 12:15 PM   #5
CoolGuyDave
do a search for "lug nut remover" on matcotools.com... they sell sockets that will take them right off....
PS- try the other methods first!
2002 Overland Build/Pic Thread
NIU Mechanical Engineering Grad
"EAT, SLEEP, JEEP!"
CoolGuyDave is offline   Reply With Quote
Unread 01-27-2008, 12:37 PM   #6
driabyor
1994 ZJ
hey it may work .. look at wal mart ... if it doesn't ... take it back.
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline   Reply With Quote
Unread 01-27-2008, 12:49 PM   #7
indept
Try sears. Here's a link for stripped bolt/nut remover
http://www.sears.com/shc/s/search_10...&gobutton=find
2000 WJ 4.0L 42RE 242 TC
172,271 miles & counting
indept is offline   Reply With Quote
Unread 01-27-2008, 01:03 PM   #8
manofmany
Just like said above, pounding a smaller socket on is the best way. Had to do it before for some locking lugs that I didnt have the key for. Same thing the tire shops do.
1998 Cherokee 4.0L
1999 Grand Cherokee Limited 4.7L
manofmany is offline   Reply With Quote
Unread 01-27-2008, 02:09 PM   #9
Virmagicus
Headed Out West
Virmagicus's Avatar
I use this also for stripped bolts etc.. A nut buster just might do the trick also.
Virmagicus is offline   Reply With Quote
Unread 01-27-2008, 02:53 PM   #10
CoolGuyDave
you could also chisel them off as a last resort....
"EAT, SLEEP, JEEP!"
Unread 01-27-2008, 03:04 PM   #11
NoOne2
I had 3 lugs on my WJ that would not come off after we bought it.
I tried it all...including my 600ft lb impact gun...they were stuck. I ripped open several sockets, tore them right in half...
So...if your good....you can torch them off...without damaging the wheels.
I had a local shop do it and it worked, left very slight brown marks on the clear that came right off with some polish.
Sounds like a idea but same with the chisel, one slip and the wheel is done.
-- Eric
2000 4.7l Grand Cherokee Laredo
2000 Pewter Corvette
NoOne2 is offline   Reply With Quote
Unread 01-27-2008, 03:28 PM   #12
impuresoul2k3
Ripped apart? Did you use impact sockets?
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline   Reply With Quote
Unread 01-27-2008, 05:57 PM   #13
Marky1
Thanks everybody for your help + input. I now have some idea what to do to get this taken care of. Many Thanks,......
Unread 01-27-2008, 07:59 PM   #14
dickensheets
Do you have a buddy with a welder? Weld a socket onto it as a last resort.
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline   Reply With Quote
Unread 01-27-2008, 08:06 PM   #15
Zues Greason
1994 ZJ
Just take it to discount tires. I used to work there as a kid. they will get it off real fast.
Zues Greason is offline   Reply With Quote
