Stripped lug nuts?? - JeepForum.com
post #1 of 15 Old 02-25-2007, 12:14 PM Thread Starter
rustycherokee18
Stripped lug nuts??
Any one have any tips or tricks how to remove stripped lug nuts?? The lug nuts basically snapped in half and easy outs arent helping at all. All they are doin is strippin them even more. Any ideas??
rustycherokee18 is offline
post #2 of 15 Old 02-25-2007, 12:28 PM
SAZJ
vicegrips? They also sell those gator sockets at walmart that are supposed to latch on even if the blot is stripped.
SAZJ is offline
post #3 of 15 Old 02-25-2007, 12:38 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
I'm having trouble visualizing what you mean by "The lug nuts basically snapped in half " Are you able to post a pix? Did this happen to all the nuts?
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #4 of 15 Old 02-25-2007, 12:42 PM
Vestjam
I've never seen a lug nut split in half. I've seen the studs break though. If it's the 'stud post' and not the 'lug nut', you have two options... maybe more...
Option 1: Get a good C-clamp and place it behind the spindle while keeping the other end on top of the stud.... tighthen... that should drift the stud out.
Option 2: brace the back of the spindle with something and then hammer out the stud.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #5 of 15 Old 02-25-2007, 01:09 PM Thread Starter
rustycherokee18
this is the lower half of the lug nut still on the stud
http://pictures.sprintpcs.com/share....tate=RETRIEVED
This is the upper half that broke off
sry for the poor quality its off my phone
post #6 of 15 Old 02-25-2007, 01:34 PM
Slamm36
Slamm36's Avatar
most lugs have a cover on them it looks to me liek that is the cover that came off?
-Wyatt
1996 Laredo 4x4 I6 177800 Miles - Slightly Modified
Optima RedTop | BFG T/A KO's 30x950 | 22" Cherry Bomb
KOR Crossmemeber | V8 UpCountry Springs | Dayton Timberline MT 31x1050
K&N Drop-In | Homemade QD's | KOR Radiator Support
Slamm36 is offline
post #7 of 15 Old 02-25-2007, 01:39 PM
SJZ
SJZ's Avatar
Wow! Those must be some really crappy lug nuts to do that! Or maybe they were installed cross threaded with an impact wrench.
If you can get a female type extractor (which can fit over the broken piece), that may work (not if it was cross treaded, tho).
Or, get some cobalt drill bits and use progressively larger ones until the stud is drilled out. You should then be able to know the nut off and pop the stud out . If you has a torch, just heat the center of the stud/nut until it melts and give it a shot with a hammer. I would change all my lug nuts if I were you.
-Steve
SJZ is offline
post #8 of 15 Old 02-25-2007, 04:20 PM
02Lightning
I had to drill mine out.
2001 Jeep Grand Cherokee Laredo 4.0L NV242LD Transfer Case, 42RE, 119,500 miles
02Lightning is offline
post #9 of 15 Old 02-25-2007, 06:12 PM
gunthagunth
gunthagunth's Avatar
yeah that looks sucky. probably need to drill it out. Start with small bits and slowly move up. Keep the drill at a low speed to keep a tip on your bit and use a bit of oil too. Not sure if you can fit it but if you have a 5/8 or 3/4 12pt half inch socket? I cant remember exactly but you might be able to hammer it on there really deep and tight and back it off with a impact gun. Looks tight in there so it may not work but Id give it a try.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #10 of 15 Old 02-25-2007, 06:16 PM
1995zj
i had a lug nut stripped on my old truck, ended up beating a smaller socket onto the lug eventually with beating it on it got a good bite and we got it out
Platinum 5.9l, K&N FIPK, Kolak 3" exhaust, SCT Tuned, Flowmaster 50 series, Doug thorley headers, E-Cutout, 180 thermostat, Fastman 52mm TB, Ported Kegger, Stillen rotors
1995zj is offline
post #11 of 15 Old 02-25-2007, 06:56 PM
02Lightning
I tried that too, I still ended up drilling it out.
post #12 of 15 Old 02-25-2007, 08:06 PM Thread Starter
rustycherokee18
So yea after a few hours of tring different things we finllay got it. I eneded up having to drill em out. So thanx for the help yall its really appreciatd. I thank everyone for there input and advice
post #13 of 15 Old 02-26-2007, 10:50 AM
dickensheets
I wonder if JB welding a socket to it overnite would have grabbed it??
rd
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline
post #14 of 15 Old 02-26-2007, 12:56 PM
Yardman Harry
O
Yardman Harry's Avatar
Defiently have to drill it out. I just did mine, about a half an hour job. Have fun!
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #15 of 15 Old 02-26-2007, 01:06 PM
SJZ
SJZ's Avatar
rd
I don't think so.
-Steve
SJZ is offline
7mm Headlight Bolt is stripped, how can I get it out? pCarson92 ZJ Grand Cherokee Forum 6 06-19-2009 12:40 PM
Stripped Lug Nuts Marky1 ZJ Grand Cherokee Forum 34 11-08-2008 03:22 PM
Stripped Lug Screw th3godf4th3r ZJ Grand Cherokee Forum 7 04-29-2007 08:14 PM
Help! Stripped lug nut! 7tiger7 ZJ Grand Cherokee Forum 4 01-22-2006 02:50 PM
Stripped threads - What are my options? Radiac ZJ Grand Cherokee Forum 4 01-21-2006 08:22 PM
