Stripped front cv axle stud - JeepForum.com
post #1 of 3 Old 07-20-2009, 09:43 AM Thread Starter
02grand
I have a 02 grand with np242 and on the front right axle the hub nut stripped out and now the axle is useless because the nut wont go on. My question is, is there a truck that I can switch that outside cup where the abs tone ring is with to not have to change the whole axle. The axle is 100 from autozone but awd is cheaper. Is there a difference and can this be done? Thanks for any help.
02grand is offline
post #2 of 3 Old 07-20-2009, 10:47 AM
doublejz
how bad is it stripped? is it just the end threads?
Why not chase the threads or run a die over it and get a new nut?
04 WJ with some stuff -
doublejz is offline
post #3 of 3 Old 07-21-2009, 08:38 AM Thread Starter
02grand
it actually created a hole in threads where nut can slide back and fourth without even grabbing threads. No way i could retap but thanks for advice. Wish i could use!
02grand is offline
Axle Shafts, Gerotor Pumps, Clutch Plates,... oh my! Is my front axle a vari-lok? 99avant WJ Grand Cherokee Forum 16 08-11-2011 08:47 PM
4x4 front axle oil vs rear axle oil sdowney717 ZJ Grand Cherokee Forum 13 07-09-2009 10:45 PM
changing front axle shaft..axle nut lakailimited06 ZJ Grand Cherokee Forum 2 06-14-2009 08:40 AM
Stripped front axles and hubs now I dont have park? ZJeepn08 ZJ Grand Cherokee Forum 11 04-26-2009 09:25 AM
Replaced front axle/CV joint now a bad whining from front end? f1rz06 ZJ Grand Cherokee Forum 4 09-16-2004 02:48 AM
