Stripped front axles and hubs now I dont have park? - JeepForum.com
post #1 of 12 Old 04-23-2009, 04:39 PM Thread Starter
ZJeepn08
2007 WK
Is this possible? I have my 95 limited with fulltime 4wd in park and it wont stop rolling. I'm guessing that I stripped out the axles or axle hubs on my way home. I can sit still, in gear, with my foot on the brake and my front driveshaft, axles, and everything else spins.
Ok, now that I've given you guys and gals a little story. Would this cause my jeep to not lock in park?
ZJeepn08 is offline
post #2 of 12 Old 04-23-2009, 04:43 PM
newfieZJ
Yes , it would
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 12 Old 04-23-2009, 04:50 PM
sdowney717
it could get so bad the front shafts will spin and catch fire from the friction. You will have flames pouring out the sides as you run down the interstate.
Other drivers will so you pass with glowing red hot hubs.
sdowney717 is offline
post #4 of 12 Old 04-23-2009, 04:54 PM Thread Starter
ZJeepn08
2007 WK
Well good thing I made it home.
ZJeepn08 is offline
post #5 of 12 Old 04-23-2009, 07:02 PM
comptiger5000
Any 93-95 GC with fulltime 4x4 will roll in park if the front driveshaft is removed or can otherwise spin freely.
comptiger5000 is offline
post #6 of 12 Old 04-23-2009, 09:35 PM Thread Starter
ZJeepn08
2007 WK
Why is that? the open diff? transfer case?
ZJeepn08 is offline
post #7 of 12 Old 04-23-2009, 10:30 PM
horatio102
open center diff.
horatio102 is offline
post #8 of 12 Old 04-23-2009, 11:28 PM
iluvtruenos
Eww....seriously, an open center diff?
So the Jeep can be FWD?
HAHAHAHAHA! You've got a Patriot!
iluvtruenos is offline
post #9 of 12 Old 04-24-2009, 12:23 AM
baxy
strange that the early ones can freewheel , I wasnt aware that there was two different VC
or mainshafts in the 249
baxy is offline
post #10 of 12 Old 04-24-2009, 05:11 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's not far from an open center differential, but it's not quite the same thing.
ratmonkey is offline
post #11 of 12 Old 04-24-2009, 06:05 AM
comptiger5000
The 249 is basically an open diff with a viscous coupling in the middle. When one driveshaft spins faster than the other, the VC heats up and becomes partially locked. Due to design changes, 93-95 249s will roll in park with a D/S removed, 96-98 won't. 93-95 are not locked in 4LO, 96-98 are.
post #12 of 12 Old 04-26-2009, 09:25 AM Thread Starter
ZJeepn08
2007 WK
Update:
Took the hubs and axles out and found that both cv joint boots were torn and everything on the inside was missing from the driver side axle. It's amazing how much better this thing drives now. I increased 3mpg and I think it solved the control problems on the highway. w00t w00t!
ZJeepn08 is offline
99 GCL V8 - Front end clicking. Replaced HUBS and AXLES, Still noise. NOCARRIER ZJ Grand Cherokee Forum 30 02-24-2010 01:47 PM
Stripped front cv axle stud 02grand ZJ Grand Cherokee Forum 2 07-21-2009 08:38 AM
97 ZJ Eating Up Front Hubs li'l jeep ZJ Grand Cherokee Forum 14 03-21-2009 03:43 PM
Wipers dont Delay or self Park 72MARIO ZJ Grand Cherokee Forum 3 02-05-2007 09:08 AM
replacing u-joints at the front hubs njrealtor55 ZJ Grand Cherokee Forum 25 01-11-2006 08:11 AM
