Strange noise when turning - JeepForum.com
post #1 of 8 Old 06-09-2013, 02:54 PM Thread Starter
PhoenixZJ
I have a 4.0L ZJ 4x4 with about 200K miles. I have a strange, I would say thumping noise, and my jeep goes up and down as well when I take a hard left turn. It only happens when the jeep is warmed up. Does anyone have an idea on what it could be?
Thanks,
PhoenixZJ
PhoenixZJ is offline
post #2 of 8 Old 06-09-2013, 05:05 PM
JasonStebbins
Do you have the 249 transfer case? Those sound like symptoms of a bad Viscous Coupler. When the fluid inside goes bad it makes it 4x4 all the time so that would be the hopping around turns.
Check your rear sway bar bushings and links. How is the condition of the shocks?
How are the control arm bushings?
Poop
JasonStebbins is offline
post #3 of 8 Old 06-09-2013, 05:18 PM Thread Starter
PhoenixZJ
I believe it is the 249. It only hops around when I turn left. It's smooth when I turn right. The bushing were just replaced and shocks are still good. Control arm bushings probably need to be replaced. I know at least the upper ones do
post #4 of 8 Old 06-09-2013, 05:22 PM
Rich93ZJ
If the only options you have on your transfer case are 4hi N 4lo, then you have the 249. If this is the case the above quote is spot on
Rich93ZJ is offline
post #5 of 8 Old 06-09-2013, 05:26 PM
dnuccio
ive never heard of one that only binds turning left. anythings possible i guess. go in a big empty parking lot and do some figure 8s. that will tell you for sure.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 8 Old 06-09-2013, 05:27 PM
JasonStebbins
Do some figure 8s in a parking lot and that will tell you the condition of the VC.
Do you have U-joint axles? A bad joint can cause this too.
Poop
post #7 of 8 Old 06-10-2013, 10:49 AM Thread Starter
PhoenixZJ
I do have the 249 transfer case and I will go do some figure 8's in a parking lot today and report back. JasonStebbins I don't know if my stock jeep has u-joints or not.
post #8 of 8 Old 06-10-2013, 08:16 PM Thread Starter
PhoenixZJ
So I did some figure rights and it happened on both sides so I guess it's the vc I need to replace?
