stock bumper question. 1998 grand cherokee - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > stock bumper question. 1998 grand cherokee
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-12-2014, 04:29 PM   #1
ptpdub
is there any metal under the 2 protruding front bumper plastic parts? The parts I am referring to would be the first part to touch something if you were trying to push it with the jeep. What I want to do is mount a home made light bar to them by drilling through the plastic (from the top down) and bolting the metal light bar mounts to the bumper steel. I don't want to pull the bumper cover off or do anything too elaborate. This is only for lights, not a winch or tow hooks. thanks in advance for your time.
ptpdub is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 06:17 PM   #2
itiswhatitisxj
I think the bumper end caps have about 4-8 inches of the metal bumper under them. But its flush and continuing with the metal part of the the middle bumper. It doesn't protrude. Don't be lazy, if you're going to take the time to drill into YOUR bumper, you need to take the time to inspect whats under there so YOU can make it happen. It is real easy to take those bumper end caps off. Just do it
itiswhatitisxj is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 06:49 PM   #3
MJR
Nothing but foam under the bumperettes on a ZJ. Further back a metal beam.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 07:34 PM   #4
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Welcome to the forum.
I moved this thread to the Grand Cherokee forum section where your fellow ZJ drivers can best assist.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
chris87xj is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 07:38 PM   #5
vlackattack
Yeah, there's a good couple inches of foam between that and the metal bumper...
vlackattack is offline   Reply With Quote Quick reply to this message
Unread 11-13-2014, 06:17 AM   #6
Timo_90xj
Timo_90xj's Avatar
..or as it is on the Euro- ZJs & WJs (ZG/ WG), there's absolutely nothing inside the front or rear bumpers. They're just an empty plastic shell. Pedestrian safety..
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 01:29 PM   #7
ptpdub
thank you
Unread 11-14-2014, 01:30 PM   #8
ptpdub
ok, on to plan B ..... soon as I figure out what that might be.
Unread 11-14-2014, 01:33 PM   #9
ptpdub
hope not, my worry isn't people, it is frozen snow drifts (-40 is a regular occurrence) as well as deer, moose ...... other 4 legged critters thus the lights and future push bar.
Unread 11-14-2014, 03:00 PM   #10
Aceladriver
Just so you can picture it better...
This is as far forward as any metal goes on the ZJs.
Then from there forward you have all this plastic, lol. 93 parts pictured here but for the sake of discussion, assembly-wise it's comparable to what you'd find on your 98.
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline   Reply With Quote Quick reply to this message
Unread 11-15-2014, 08:20 AM   #11
MongoAk
For LED's and so forth on mine, I mounted some 3 1/2" by 6" lights where my factory fog lights are on my 98. They are to bright to drive with into traffic, but with a push of a button I have some extra light, or a 30" bar tied into my high beams. But it was pretty easy to tie mount them on the bottom side of the bumper.
98 ZJ limited 360:Intake, exhaust, Lift,Roof Rack, and lights!
06 Cummins: "SLIGHTLY" Modified.
MongoAk is offline   Reply With Quote Quick reply to this message
