Still shifts wrong, only 2nd to 3rd - JeepForum.com
post #1 of 10 Old 07-14-2015, 04:33 PM Thread Starter
kb9mfd
I had transmission issues, 1st would take a long time, if ever, to shift to second and second would skip to third a lot and it leaked fluid like crazy so I have now replaced it with a used one from a salvage yard. I didn't at first remember to put the tv cable spring back so the new one didn't shift right either, but I now remembered to put it in and now its much better, but I still have a issue. First to second is fine, on a normal stop to highway speed it will shift to second at about 2k perfectly, but then it almost immediately shifts to 3rd. (RPM goes to 1.6 then to 1.4) Then there is no acceleration and it dogs, once it catches up to speed again the shift the 4th is at the right time (around 1.8k to 2k) If I try to punch it while its in 3rd to get it to upshift back to 2nd it doesn't and just chugges along. I can use the shifter to force it into 2nd and then put it back to D when its at speed. If I start in 2 and it shifts fine to second, I then wait until I get to 2k then put it into D everything is perfect. At first I figured its the tv cable still off but would that not effect all shifts not just 2nd to 3rd? What all factors are used to determine the shift time, could the computer be messing up? Fluid is fine, normally the 1st to 2nd is effected the most with low fluid (learned that from the other tranny) Is there a specific valve, solenoid, spring, ect... that would cause it to mess up just that gear? Other odd thing is it shifts almost perfect if I am towing, lighter the load the worse the issue. Also sometimes it shifts perfect, normally when its been on the road a while but not quite full temp. Any other ideas?
kb9mfd is offline
post #2 of 10 Old 07-14-2015, 04:39 PM
XJ93
Have you properly adjusted the t/v cable per service manual instructions?
XJ93 is offline
post #3 of 10 Old 07-14-2015, 05:17 PM Thread Starter
kb9mfd
Yes, and I tried to move it up and down a little from that. It only changes the overall shift time but it still likes to skip 2nd. It really struggles if I set it to shift earlier as the rpm in 3rd would only be around 1k.
kb9mfd is offline
post #4 of 10 Old 07-14-2015, 05:21 PM
kg6mov
Hears the voices
kg6mov's Avatar
You can adjust the 2-3 band if you drop the pan. Good idea to do that and replace the filter anyway.
Procedure here: http://www.jeepforum.com/forum/f13/b...6/#post3073349
kg6mov is online now
post #5 of 10 Old 07-15-2015, 01:12 AM
jnicewan
The 2nd gear/intermediate band (aka front/kickdown) is adjusted externally, right between and slighty above the shift linkage and where the front cooler line goes into the case. The low/rev band is the one that gets adjusted from inside the pan above the filter. The front band can cause shifting issues with 2nd gear, its only applied in 2nd. Usually the concerns are in the quality of the shift, not so much in timing of the shift but its a good place to start.
jnicewan is offline
post #6 of 10 Old 07-15-2015, 08:35 AM Thread Starter
kb9mfd
I did adjust that one when I put it in, its rather hard to adjust when its in place. I followed the instructions to adjust it. I forgot to adjust the back band.
kb9mfd is offline
post #7 of 10 Old 07-16-2015, 03:49 AM
gearheadnick
There's a spring inside the trans that's prone to breaking, but that controls the 3-4 shift. You can see where it is in the write up in my siggy.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #8 of 10 Old 07-16-2015, 10:57 AM
CatAndTie
Yeah, I think mine is having a similar issues, but it hasn't been too bad that I needed to address it right now.
Mine happens when I'm at a stop and need to punch it to pull out quickly to get up to speed. I haven't hooked mine up yet to really look at the shifting, but I think it feels like it's "skipping", maybe slipping? But it feels like it is only between either 1 and 2 or 2 and 3. All of the other shifts feel fine.
Please keep us updated with what you find out. I think I am going to change out some of my fluid, and maybe adjust the cables/bands.
CatAndTie is offline
post #9 of 10 Old 01-19-2016, 07:40 PM
IndyJeeper
I had this exact issue. After I replaced the caps in the pcm for a totally unrelated reason, the transmission works perfectly now. http://www.jeepforum.com/forum/f13/f...riteup-501951/
IndyJeeper is offline
post #10 of 10 Old 01-20-2016, 09:59 PM
robrtsmtn
the 3-4 accumulator spring. I agree, many of them break on the 42RE. Cascade Transmission Parts online has great solenoid kits with this part.
1993 ZJ 4.0 By summer it will be ready for fly fishing the high country, maybe.
robrtsmtn is offline
transmission , transmission issue
