still rough idle?? - JeepForum.com
post #1 of 10 Old 12-21-2007, 04:00 PM Thread Starter
lakailimited06
still rough idle??
ever since i had all my fluids changed/replaced ( all correct fluids ) and a tuneup done ( included:spark plugs replaced fuel injectors also cleaned ) my wj seems to be idling rough when stopped in drive and sometimes when parked..i brought it back to the mechanic which he then told me that the 5th cylinder was occasionally missfiring but not to the point where it was going to become a problem..he then said he cleaned the spark plug and fuel injector again which seemed to cure the problem for that day..next day same problem..recently my wj stalled out on me and i had to have the cam and crank sensors replaced which seemed to reduce the idling problem but it still wasnt normal..could my K&N intake be causing this rough idle, and how bad is this long term/short term...any responses/suggestions are greatly appreciated..
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #2 of 10 Old 12-21-2007, 04:13 PM
greasefingers
greasefingers's Avatar
1994 ZJ
If the misfire is enough for you to notice it, then that is too much for me. A long term misfire is never a good thing even if it is occasional. Eventually, carbon will build up make that cylinder hotter than normal and then a misfire will always be present.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 10 Old 12-21-2007, 05:21 PM
Briandl
It's your K&N, I'd get rid of that junk if I were you, I'd charge you maybe 5.00 to dispose of it...
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #4 of 10 Old 12-21-2007, 05:42 PM Thread Starter
lakailimited06
i know alot of other guys have intakes do any of them experience the same thing? i got rid of the stock intake and really dont want to purchase another one...any other alternatives??
99WJ 4.0
post #5 of 10 Old 12-21-2007, 07:35 PM Thread Starter
lakailimited06
could it possibly be that the temperature on long island right now is ranging from like 25 to 35 degrees outside along with the intake?
99WJ 4.0
post #6 of 10 Old 12-21-2007, 07:42 PM
greasefingers
1994 ZJ
No that temperature is simply common for any engine. Thatís why the MAP & Intake temperature sensor are there.
I am not familiar with the 1999 engine. Do they by chance have a MAF (mass air flow) sensor in the intake? As these need to be periodical sprayed with electrical cleaner to remove residue (or in the case of K&N to remove any oiled filter scum)
Cheers Steve
post #7 of 10 Old 12-21-2007, 07:43 PM
greasefingers
1994 ZJ
Since the issue developed after a lot of work was done, I would check for loose vacuum hoses on the Intake manifold.
Cheers Steve
post #8 of 10 Old 12-21-2007, 08:37 PM Thread Starter
lakailimited06
will do..appreciate it
99WJ 4.0
post #9 of 10 Old 12-21-2007, 10:09 PM
Vestjam
I can't remember a time when I ever disagreed with Greasefingers...
I was thinking vacuum leak before reading that above caption. The next thing I would consider is if the 'tune up' included cap/rotor/wires along with those new plugs.
Oil from a K&N can mess up a Mass air if there is too much oil on it. The FORD's mass air definitely doesn't like too much oil on the filter.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #10 of 10 Old 12-22-2007, 07:36 AM
greasefingers
1994 ZJ
Thanks for the kind words. And keep that 5.9 happy for the holidays
Cheers Steve
242 Has a Rough Idle. Some_Anchovies ZJ Grand Cherokee Forum 30 10-04-2009 10:39 AM
02 Gc With Rough Idle, 4.0 Rough... evanlaczi ZJ Grand Cherokee Forum 4 05-09-2009 04:53 PM
rough idle fearthedeere69 ZJ Grand Cherokee Forum 8 08-13-2007 11:34 PM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 08:43 AM
rough idle baroc ZJ Grand Cherokee Forum 0 03-18-2007 09:06 PM
