still losing oil.???? - JeepForum.com
post #1 of 5 Old 06-22-2009, 05:07 PM Thread Starter
jeepjoker
93 ZJ 4.0 limited auto 215,xxx. i recently had a shop do my leaks in my system. they did the rear main seal, and oil pan for the engine (i did my valve cover)and front and rear on trans etc.. and i'm still losing oil. . so how do i test to see if my engine is burning oil? do i do a wet compression test? or???? am i doomed for losing oil? and how do i replace the oil level sensor(not the oil pressure sensor, but the sensor in the oil pan that shows how low i am.) any suggestions?
thanks
jeepjoker is offline
post #2 of 5 Old 06-22-2009, 05:49 PM
sadass
It is not uncommon for bad valve guide seals , I had my head done on the same year 4.0 ZJ at a high milage, no more oil consumption. or at least back to a normal level of consumption. But I would due a compression test before having the head done.
As for the level sensor, check the connections before replacing. I have seen the wires pulled out on two occasions now!
fond this
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #3 of 5 Old 06-22-2009, 05:56 PM
sadass
sorry about that, try this link
http://www.justanswer.com/questions/...cherokee-4-0-l
sadass is offline
post #4 of 5 Old 06-22-2009, 06:11 PM Thread Starter
jeepjoker
i tested my compression a months a go and i got
Cylinders
1)115
2)120
3)130
4)135
5)90
6)120
(cold)
but this wasn't a wet compression test. should i do that? i also ran some sea foam in my intake but have not checked compression since. and if i had to remove my head is hard to do? also do the sensors go out allot. i have a feeling mine works good cause when its low i check the dipstick and its low. and when its not low the dipstick says its not low also. so should i even worry about that? my sensor doesn't go off all the time
post #5 of 5 Old 06-22-2009, 08:17 PM
xJoshxx
2012 WK
Cylinders
1)115
2)120
3)130
4)135
5)90
6)120
(cold)
Cylinder Compression Pressure Range 827 - 1034 kPa (120 - 150 psi)
Maximum Variation Between Cylinders 206 kPa (30 psi)
your number 5 is running kinda low. it's 30+ below on some of the other pistons
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
ZJ losing Idle.... zjilla ZJ Grand Cherokee Forum 14 08-05-2012 06:36 PM
Losing Oil Pressure ????? DEEPERTHEBETTER ZJ Grand Cherokee Forum 7 01-10-2009 07:25 PM
Losing power?! nddigi WK Grand Cherokee & XK Commander Forum 2 12-31-2007 07:18 AM
Losing Water kopite77 ZJ Grand Cherokee Forum 27 10-06-2007 02:19 AM
losing motivation.. MotoX5874 ZJ Grand Cherokee Forum 10 07-21-2007 10:52 PM
