still learnin - JeepForum.com
post #1 of 5 Old 12-08-2011, 08:07 PM Thread Starter
yungzj
1994 ZJ
still learnin
i have a 94 zj with a 5.2l v8 thats full time 4wheel and i was wonderin if anyone could help me figure out what transfer case i have now and what they would recomend if i wanted to swap it out
yungzj is offline
post #2 of 5 Old 12-08-2011, 08:28 PM
AmishFury
right now you have the 249 if the VC is still good there's not much need to swap unless you really want 2WD option
242 is probably the most popular option with the 231 as an alternative... the difference between the 2 is the 242 has the full time 4WD option
AmishFury is offline
post #3 of 5 Old 12-08-2011, 08:30 PM Thread Starter
yungzj
1994 ZJ
if i did swap it out would i have to do any other modification to make it work
yungzj is offline
post #4 of 5 Old 12-08-2011, 08:36 PM
19YJ91
On a 94 I beleave the swap is pretty in-depth there is a writeup on it on here that should answer all the technical questions on the swap.
19YJ91 is offline
post #5 of 5 Old 12-08-2011, 08:39 PM
AmishFury
http://www.jeepforum.com/forum/f13/t...-np242-685644/
the standard link for more info on the swap
transfer case swap , zj
