steering wheel shakes - JeepForum.com
post #1 of 17 Old 01-14-2008, 05:11 AM Thread Starter
peepmyjeep00
i just got my 00 grand cherokee & i've notice the steering wheel starts to shake really bad when i get to about 40-45mph & then usually stops alittle bit when i hit 55-60mph. It doesn't do this every time but it seems to be happening more often. The alignment doesn't seem to be off!! Does any1 know what the prob might be?
peepmyjeep00 is offline
post #2 of 17 Old 01-14-2008, 05:22 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
have you had it in for an alignment? check the balance on the tires as well.
ratmonkey is offline
post #3 of 17 Old 01-14-2008, 06:10 AM
UUJ1
Have your tires balanced, or rotate them to start off with.
Vibrations come from tire balancing NOT alignment.
'99 4.7 WJ,
3" IRO/Addco rear sway bar/ 31x10.5 Pro Comp XMT's(Yes, I changed my mind and decided on these)/ Pro Comp Mountain Crawler soft 8's 15x7 w/3.75" BS
242 in my garage... still
UUJ1 is offline
post #4 of 17 Old 01-14-2008, 07:33 AM
x saturn x3
Check your steering dampener, it may be on its way out.
If you dont know what it is, its that shock under the front end of your car that connects to the steering linkages.
1995 Saturn SL2 automatic (48,005 mi.)
1995 Saturn SL2 manual (149,xxx mi.)
1998 Saturn SL2 automatic (FREE!)
x saturn x3 is offline
post #5 of 17 Old 01-14-2008, 09:26 AM Thread Starter
peepmyjeep00
no i haven't checked that out but i will~how do i know if it needs to be replaced?
post #6 of 17 Old 01-14-2008, 10:22 AM
kingvm
kingvm's Avatar
2005 WK
A shake like that at specific speeds are almost always tire balance related.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline
post #7 of 17 Old 01-14-2008, 11:49 AM
Jeffros ZJ
As others have posted I'd check your alignment and tires checked and balanced.
Jeffros ZJ is offline
post #8 of 17 Old 01-14-2008, 12:30 PM
x saturn x3
If its either leaking the fluid inside it or there is play in it. To check play, jack up the front of the vehicle and put it on jackstands. Wiggle the wheels left to right (as if you're turning the tires either direction with your hands)
If you feel a slight wobble or some play, wiggle it while looking at the steering dampener. If the steering dampener is moving with ease, its shot. It acts just like a strut. Its hard to compress them quickly, and hard to extend them quickly. If it moves quickly, its bad
Also could be a tire balance issue
Does it get better or worse when you step on the brake when its doing it?
post #9 of 17 Old 01-14-2008, 06:32 PM Thread Starter
peepmyjeep00
i just drove it around & it only happens @ about 42-45mph & stops around 50mph. When i stepped on brakes it seemed to stop i think
post #10 of 17 Old 01-14-2008, 06:41 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Swap the front tires out with the rear. See if the problem goes away altogether or if the problem follows the tire(s).
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #11 of 17 Old 01-14-2008, 06:44 PM Thread Starter
peepmyjeep00
OK i will definitely try that first thing
post #12 of 17 Old 02-04-2008, 10:54 PM
freekmccoy
me too
mine does it real bad after I hit a bump in the road,steering wheel shakes violently then it straightens out...it seems to be doing it more often though.
freekmccoy is offline
post #13 of 17 Old 02-04-2008, 11:14 PM
driabyor
driabyor's Avatar
1994 ZJ
and worn shocks.....
or a bent or damaged wheel....
bad tire....
a missing lugnut.....
mud on the inside rim or a blob of grease..
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #14 of 17 Old 02-05-2008, 07:33 AM
WJChris
WJChris's Avatar
NOT true. Caster causes wobble/vibrations.
ever get that shopping cart in the market with that wobbly wheel.... caster.
WJChris is offline
post #15 of 17 Old 02-05-2008, 07:34 AM
WJChris
WJChris's Avatar
That sounds like Death wobble...
Your SS is probably bad if your vehicle is stock
WJChris is offline
Steering wheel shakes driving over bumps and braking bigburb1 ZJ Grand Cherokee Forum 20 06-16-2011 05:55 AM
had 4 wheel aligment twice i past week, and steering wheel is still off center..Help HD-ZJ ZJ Grand Cherokee Forum 4 11-24-2009 01:54 PM
broken steering column / steering wheel loose? theksmith ZJ Grand Cherokee Forum 2 04-19-2009 09:49 PM
steering wheel shakes iratically 02grand ZJ Grand Cherokee Forum 21 05-21-2007 12:51 PM
steering and steering wheel acting wayyy differently GRDCHRKE555 ZJ Grand Cherokee Forum 10 03-22-2007 07:20 PM
