Steering wheel puller help, I broke something :( - JeepForum.com
post #1 of 8 Old 09-13-2009, 03:17 PM Thread Starter
pauler
So basically heres the story. .. I bought an overland steering wheel (wood grain, black perforated leather ) to replace my ratty old one, but in the process of taking the old one off I somehow completely broke off the notch where the steering wheel puller sits. It was almost off and I heard a loud *POP* and my steering wheel puller went one way and a shard hit me in the face lol. I'm fine just a small cut and a bruised ego, but what can I do now? My puller keeps sliding out from one side so I have to drill myself a hole I guess? How should I go about doing this?
I was looking around an I found a FAQ explaining this
JeepsLimited.com - Steering Wheel Removal & Replacement (WJ)
Now I just dont get it, did he drill and tap his own holes and stick a existing bolt in there, or did he just drill a hole the right diameter and just jam the bolt in there? I'm scared of drilling too far and messing stuff up, can anyone recommend what type of shop I should go to and have them do it?
01' Silverstone WJ Limited
-Debadged, K&N CAI, Quad taillight mod, Yellowtop Optima, 3000 watt stereo setup, Kolak 3' Catback (flowmaster 70 with magnaflow tip and high flow magnaflow cat) with DMH electric cutout, Overland woodgrain wheel
pauler is offline
post #2 of 8 Old 09-13-2009, 03:24 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Yeah I had the same problem. I was surprised how weak the structure was being cast aluminum. They have a special puller at the stealership to do this. My puller came off so I drilled 2 holes just off the main shaft. I then tapped them for a 5/16 bolts. I was then able to put my regular triple head steering wheel puller on it. It popped right off once you get the forced centered around the shaft. Its a retarded design IMO.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #3 of 8 Old 09-13-2009, 04:39 PM Thread Starter
pauler
You think the stealership puller would still work considering i cracked off a chunk of aluminum or is my only option now what you suggested? I dont even own a proper drill not to mention tools for tapping the hole, so it may just be cheaper for me to get the stealership to do it?
pauler is offline
post #4 of 8 Old 09-13-2009, 04:42 PM
WiCkeDuDe
WiCkeDuDe's Avatar
If you broke that notch on the side then the dealer puller will not work any longer. I think you will need to drill some holes IMO.
post #5 of 8 Old 09-13-2009, 05:01 PM Thread Starter
pauler
Damn thats what I was afraid of ... I'll give it a go tomorrow if it doesnt work I'm just going to get a local shop to do it.
pauler is offline
post #6 of 8 Old 09-15-2009, 09:12 AM
tbm5690
Just did this a month or so ago...drilling is an absolute must as using a 2-jaw puller with the notches is either going to break the notches like in your case or bend the puller like in my case. Go to Autozone/O'Reilly/Carquest/Advance and ask to rent a steering wheel puller kit. Mine was free...and it comes with different sized bolts. Use a regular old drill bit appropriately sized, screw in the bolts, and crank her down. Done. The only problem I ran into was the brittle aluminum being stripped by the pressure of the bolts being pulled...a couple of times they stripped out the holes. Basically, drill small and use force to thread the bolts in.
After it's all over you feel great...this was hands down the worst/hardest/most frustrating job I have ever had to do on the old WJ
2001 Grand Cherokee Laredo S/A package 4.7L V8
K&N high-flow filter, Airaid MIT, Flowmaster 50 catback
tbm5690 is offline
post #7 of 8 Old 09-15-2009, 09:39 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
I have pulled at least 7 WJ steering wheels, and the one-and-ONLY way I could do it was with a 3 jaw puller. I tried several pullers before, and found the 3-jaw once the Vatozone employee let me in the back to look at their vast variety of rental tools they tell no one about.
Were you using a 3 jaw?
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #8 of 8 Old 09-15-2009, 09:40 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Do NOT use a "steering wheel puller". This is for older cars. You will waste soo much time. Why would you drill holes?
Wheel stud broke, cant get wheel off MurdaJs Grand Cherokee General Discussion 23 05-19-2010 12:24 PM
ZJ steering Dampener stuck, puller needed? paddingtonbear ZJ Grand Cherokee Forum 9 09-12-2009 11:39 PM
Broke a nut installing steering brace SnowLeopard ZJ Grand Cherokee Forum 6 07-01-2009 11:01 PM
Steering broke !, what is this? please :) Mr_Grumpy ZJ Grand Cherokee Forum 6 04-03-2008 12:16 AM
Steering wheel radio control broke...need help BostonBull ZJ Grand Cherokee Forum 3 10-12-2006 08:28 PM
