Steering Stabilizer - JeepForum.com
post #1 of 53 Old 03-17-2008, 04:53 PM Thread Starter
Windowsrookie
Steering Stabilizer
I'm trying to replace my steering stabilizer (because It's stock) and it won't budge. I've been spraying it with PB blaster for a few days and it still won't move. The nut came off, but the bolt is still threaded into the tie rod. should I just drive it around without the nut and hope it comes loose? I don't really want to take a hack saw to it.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #2 of 53 Old 03-17-2008, 05:08 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
It's not threaded in there. That joint is tapered, so they seat in there very tightly.
If you can't pound it out with a hammer, get one of these: http://www.harborfreight.com/cpi/cta...emnumber=38649
I did mine a couple weeks ago, and it took a lot of pounding with one of those tie rod end separators.
'09 Rubicon
Kruzin is offline
post #3 of 53 Old 03-17-2008, 05:11 PM Thread Starter
Windowsrookie
hmmm, could I use my hub puller on it? Otherwise I'll head to HF tomorrow.
1987 Wrangler 4.2L
post #4 of 53 Old 03-17-2008, 05:11 PM
UTChavok
So your stuck exactly where I was.
What I did, not the smartest idea in the world, was take the tie rod end puller that I rented from autozone and put an impact wrench on the nut on the puller and go to town, took about 4 seconds before it popped out.
-Ronnie
UTChavok is offline
post #5 of 53 Old 03-17-2008, 06:08 PM
DTrem08
Yup, get a TRE puller. My bolt was actually getting squished and was just bending under the pressure, but sure enough there was a loud pop and it came out....
**LOOKING FOR MY JEEP, LAST SEEN IN CT and CURRENTLY HAS CT PLATES
White 1996 Grand Cherokee Laredo, I6 4.0 20% tint all around
**KOR Radiator Support, IRO 3.5" lift, 31/10.5/15" Maxxis Bighorns on 15x8 Cragar Soft 8's, JKS Bar Pin Eliminators, KOR Light Bar, 4 Black KC HiLites, Flowmaster Super 44 with turndown/no tailpipe, OME Steering Stabilizer, Black KOR square rock sliders
**If youve seen it around CT or know about it, PM me
DTrem08 is offline
post #6 of 53 Old 03-18-2008, 01:27 PM Thread Starter
Windowsrookie
I've broken a pitman arm puller, and gear puller now. Any other ideas?
1987 Wrangler 4.2L
post #7 of 53 Old 03-18-2008, 01:38 PM
ajmorell
ajmorell's Avatar
Drill out the center of the tapered bolt and try putting the puller back on it. I had to drill a good portion of the center section of mine out before it would pop out.
ajmorell is offline
post #8 of 53 Old 03-18-2008, 01:39 PM
-Joe-
-Joe-'s Avatar
you can also put an open end wrench on the part right above the bar and try to turn it..
I ended up sawing it off right above and just used a break bar with socket to turn it and it broke loose.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #9 of 53 Old 03-18-2008, 02:06 PM Thread Starter
Windowsrookie
I tried, and now it's pretty round.
I'm going to drill out the center of the bolt and try whacking it with a hammer. After that I'm stuck.
1987 Wrangler 4.2L
post #10 of 53 Old 03-18-2008, 03:12 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
The TRE separator in my first post?
'09 Rubicon
Kruzin is offline
post #11 of 53 Old 03-18-2008, 03:14 PM Thread Starter
Windowsrookie
I already tried a pitman arm separator, It broke into two pieces. And none of my local auto part stores have a TRE separator.
1987 Wrangler 4.2L
post #12 of 53 Old 03-18-2008, 03:24 PM
UTChavok
If you really cant get it out you might need to take off your tie rod and make it a whole lot easier to work with... but that would be a royal pain.
-Ronnie
UTChavok is offline
post #13 of 53 Old 03-18-2008, 04:13 PM
ajmorell
ajmorell's Avatar
Drill it out and then put the TRE puller back on it. Drilling the center section out will let some of the pressure off the tapered portion stuck in the drag link.
ajmorell is offline
post #14 of 53 Old 03-18-2008, 04:21 PM Thread Starter
Windowsrookie
I'd put the pitman arm separator back on, but it's in two pieces now...
1987 Wrangler 4.2L
post #15 of 53 Old 03-18-2008, 04:38 PM
ajmorell
ajmorell's Avatar
Well chances are beating it with a hammer isn't going to get it out.....I would just go to Autozone and rent another TRE puller from them.
ajmorell is offline
Steering Stabilizer? JLA ZJ Grand Cherokee Forum 7 12-17-2014 11:56 AM
zj steering stabilizer kidA ZJ Grand Cherokee Forum 19 05-25-2011 09:02 AM
Can't get the steering stabilizer off! Reswob ZJ Grand Cherokee Forum 19 10-30-2009 08:44 PM
Steering Stabilizer Kota04SXT ZJ Grand Cherokee Forum 2 11-01-2008 08:24 AM
Steering Stabilizer Q ben_wagner ZJ Grand Cherokee Forum 6 08-06-2006 09:15 PM
