Steering Shaft/Sector Shaft - JeepForum.com
post #1 of 19 Old 04-02-2011, 04:08 PM Thread Starter
BigRed4x4
So I have narrowed my loose steering down to the shaft that connects the steering wheel and the gear box. Now all I need to know (besides how to install it...which comes later) is where to get one. I was researching threads and someone said you could get them at O'Reilly Auto Parts. However this is concerning because I work there and could not find them under any name or in any book.
Any one got an idea?
'93 ZJ, 4.0L, D30 & D35, NP231, 4" Lift, 31" BFG's, Soft 8's, Painted Cladding, Glasspack, JVC Deck, CB, Lightbars, JKS Discos & TB, Tow Hooks Everywhere...more crap.
BigRed4x4 is offline
post #2 of 19 Old 04-04-2011, 02:28 PM Thread Starter
BigRed4x4
Bumpity 10char
post #3 of 19 Old 04-04-2011, 03:01 PM
speedbucket
and why do you think the play is there?
i dont think there is really anything to go bad with the shaft itself, but i may be wrong
more than likely the steering box is the culprit, there is a writeup on the faqs to tighten your gearbox
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #4 of 19 Old 04-04-2011, 03:22 PM
Yardman Harry
O
Yardman Harry's Avatar
Yeah. Adjust the bearing preload. My sector shaft play tightened up after this adjustment . Check the faqs as mentioned. I have a writup there to help.
Yard.
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #5 of 19 Old 04-05-2011, 08:44 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Mopar, Flaming River, Borgeson
I paid $60 for my Mopar steering shaft online. The aftermarket ones are way nicer but expensive.
Keeps the varmints on the run, boy
HighLonesome is online now
post #6 of 19 Old 04-10-2011, 04:51 PM Thread Starter
BigRed4x4
Thank you everyone. I know its the shaft because when I tighten the box to where it binds, there is still play in the shaft. The I don't carry them at O'Reilly, neither does Advance or Autozone and the dealer didn't know what I was talking about. So I'll try the companies above. Maybe I'll get some luck. People probably think I'm drunk going down the road cuz I'm all over the place!
post #7 of 19 Old 04-10-2011, 05:07 PM Thread Starter
BigRed4x4
What site did you get your Mopar shaft from. Of course I tried Mopar.com but I'm not sure on how to find the part.
post #8 of 19 Old 04-10-2011, 05:57 PM
HighLonesome
I can't find it either. Maybe it's discontinued as most ZJ stuff is becoming.
Try kolak@aol.com
post #9 of 19 Old 04-10-2011, 08:40 PM
Yardman Harry
O
Try kolak@aol.com
I found it here, which is why I decided to adjust things before dropping the money on this
http://www.mopar-wholesale.com
direct link here...
Click here if you want a shaft
Hunter Green
White
~Junked~
post #10 of 19 Old 04-10-2011, 10:40 PM Thread Starter
BigRed4x4
Thanks again y'all.
I found a Borgeson for $284, but there was a guy at work today that said he wanted to part out his Jeep after he tried pullin someone out and ripped his frame off... Anyway do y'all know what other models might be close to fittin in mine. I figure probably an XJ or maybe others.
Also, Yardman, the shaft its showing, I believe, is the one actually in the steering box. I need the one that connects the gear box to the steering wheel: sector shaft. The box is brand new and adjusted properly.
post #11 of 19 Old 04-10-2011, 11:49 PM
jnicewan
Some cars have what they call a rag joint, and others have another type of joint (dont know the name) Both are prone to develop loosness in time and they are also a weak link if you ever need to steer without power assist.
I went to a local salvage yard and removed a couple steering shafts off of other vehicles that had an actual u-joint on them. I removed my steering shaft, cut and welded the u-joint part in place. Sure you can buy someone elses steering shaft, you can also source bolt on parts etc, but the salvage yard deal cost me $10. I think the donor veh was a 90's chevy van, but there are many others out there too.
jnicewan is offline
post #12 of 19 Old 04-11-2011, 08:55 AM
HighLonesome
direct link here...
Harry,
He means the intermediate shaft, not the sector shaft. Not showing up in any searches.
Andy
post #13 of 19 Old 04-11-2011, 09:13 AM
Foundrydude
One of the metal universal joints in your intermediate shaft is bad? Did that truck used to be a taxi or something? Maybe it had a bad box that forced binding or other weirdness??
Get one from a junkyard, that is a rare failure. Which is why you're not finding them available as replacements. These intermediate shafts ought to be million mile durable.
If you're having trouble sourcing one locally, I've got a 97 steering column in the attic with a good intermediate shaft and would be happy to sell/ship. Send a PM
good luck
Foundrydude is offline
post #14 of 19 Old 05-15-2011, 10:24 AM
Dodgeram1989
1976 FSJ Cherokee
Pmd ya about the steering column
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #15 of 19 Old 05-15-2011, 10:21 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Thought you could only buy the shaft as part of the column assembly as its collapsible.
ratmonkey is offline
Replacing WJ Front Drive Shaft with Junkyard Shaft? Jonny5alive ZJ Grand Cherokee Forum 4 03-13-2011 10:53 AM
Sector Shaft - Steering box Yardman Harry ZJ Grand Cherokee Forum 2 01-06-2011 11:53 AM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 10:17 PM
Steering gear sector shaft adjustment. Mark T ZJ Grand Cherokee Forum 7 01-03-2007 04:46 PM
sector shaft difference awdco56 ZJ Grand Cherokee Forum 5 01-27-2006 03:43 PM
