Steering Shaft Replacement Options - JeepForum.com
post #1 of 9 Old 10-12-2011, 02:38 PM Thread Starter
TheAngus
TheAngus's Avatar
Hey guys,
Got a decent amount of slop in the steering shaft (gear box to column) so I'm looking into some replacement options.
Found this on jegs and figured it might be possible, but I'm not sure:
http://www.jegs.com/i/Borgeson/153/0...24#moreDetails
Let me know what other replacement options ya'll have found. Not interested in a junkyard shaft and definitely not paying the dealer an ungodly amount.
Thanks for the help guys.
-Cory
1998 ZJ Limited 5.9L l Vortech Supercharged l SCT, 42lb Bosch, 255lph l Kolak 3" Exhaust w/ E-Cutout l KOR TB Conversion l Addco Swaybars F/R l JKS Rear TB l ORO U-Turn Steering w/ OME stabilizer l RE 4.5" Springs and Monotube Shocks l IRO Rear CAs l Kolak Ignition l Clayton Fronts l
TheAngus is offline
post #2 of 9 Old 10-12-2011, 06:21 PM Thread Starter
TheAngus
TheAngus's Avatar
No one has any experience with this?
TheAngus is offline
post #3 of 9 Old 10-13-2011, 07:24 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
A little experience. I replaced it on both my ZJs. $60 from the dealer way back when. They are $92 now. I see the 98 is $171. I would find out what the difference is because Borgeson makes a direct fit for 93-95 ZJ. Otherwise I guess you could measure and spec out the right Borgeson or Flaming River shaft.
HighLonesome is offline
post #4 of 9 Old 10-14-2011, 05:09 PM Thread Starter
TheAngus
TheAngus's Avatar
I need to figure out if the Borgeson 93-95 version will work on the 98.
I thought the only difference between 93-95/96-98 was the crush capability and it looks like the 93-95 Borgeson has that.
Anyone have any insight?
TheAngus is offline
post #5 of 9 Old 01-30-2013, 06:19 PM
XJClassic
Way old post I know, but not finding anything out there if the Borgeson shaft will work on a '98. Contacted Borgeson and their response was, "we never tested it on a '98."
14MK FDII
03 CVPI
previous Jeeps: 88XJ, 93YJ, 98TJ, 98XJ, 00TJ, 98XJ, 98TJ, 97TJ, 06WK, 98ZJ,
XJClassic is offline
post #6 of 9 Old 01-31-2013, 05:59 AM
Marcos
The steering column end connection (pinch bolt) of the intermediate shaft is different between the two, as are the steering columns. The earlier steering column shaft is larger and straight, the later column shaft necks down considerably at the end.
Marcos is offline
post #7 of 9 Old 02-03-2013, 01:12 PM
XJClassic
Ok. Any recommendations ??
14MK FDII
03 CVPI
post #8 of 9 Old 06-06-2015, 06:50 PM
merc07
hate to open up a dead thread but I need a replacement shaft for my 98 and cant seem to find one so.... what he said lol^^^^^
98 4.0, 33s, 4" zone coils, IRO front double shear tb, IRO rear tb, JKS discos, crager v-5s, steering gear brace, Rustys fuel tank skid, front ADDCO sway bar, IRO "OTK" steering.
merc07 is offline
post #9 of 9 Old 06-06-2015, 07:02 PM
merc07
never mind I just found it... if anyone needs one for a 95-98, here ya go- Crown Automotive 52079050
merc07 is offline
Steering Shaft/Sector Shaft BigRed4x4 ZJ Grand Cherokee Forum 18 03-05-2014 01:14 PM
98 ZJ Fog Light replacement options rritch ZJ Grand Cherokee Forum 8 03-01-2011 04:54 PM
Replacement Battery Options rockwvu WK Grand Cherokee & XK Commander Forum 36 01-06-2010 11:10 AM
CV Joint replacement options scudman ZJ Grand Cherokee Forum 20 03-30-2007 02:24 PM
WJ front D-shaft options for CV CTORT ZJ Grand Cherokee Forum 28 01-31-2007 04:11 AM
