Steering shaft. - JeepForum.com
post #1 of 4 Old 07-09-2011, 09:55 AM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
Steering shaft.
I am about to begin the removal and installation of my steering shaft. It looks easy enough but I want to ask in advance if there is a trick to getting it off and on the gearbox and column. Or do I have to remove the gearbox to get the shaft out. The FSM only has a diagram but doesn't discuss the specifics about removing the shaft itself.
Thanks
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #2 of 4 Old 07-10-2011, 08:50 AM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
Bump. Surely somebody has done this. I decided to save this project for another day. I'm talking about the shaft with 2 universals that attaches @ the steering column & @ the steering gearbox.
post #3 of 4 Old 07-10-2011, 11:04 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Gearbox does not have to come out. Hit everything with penetrant first. Remove the heat shield. I'm thinking the airbox too just for some room to work. Then remove the two locking bolts. One from each end. Then pry the ends apart some so they will move on the splines. The shaft collapses upon itself. No reason to save this job for later. Shouldn't take more than an hour taking your time.
HighLonesome is online now
post #4 of 4 Old 07-10-2011, 01:42 PM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
Thanks, that's what I needed to know. The shaft collapses.
Steering Shaft/Sector Shaft BigRed4x4 ZJ Grand Cherokee Forum 18 03-05-2014 01:14 PM
steering box shaft ZJ1995 ZJ Grand Cherokee Forum 4 02-27-2011 01:02 PM
Sector Shaft - Steering box Yardman Harry ZJ Grand Cherokee Forum 2 01-06-2011 10:53 AM
How do I get the steering shaft out? mopar3389 ZJ Grand Cherokee Forum 1 07-19-2008 01:54 PM
steering shaft joints -Joe- ZJ Grand Cherokee Forum 4 09-26-2007 06:18 AM
