steering problems/front wheels locking - JeepForum.com
post #1 of 9 Old 09-03-2003, 12:32 PM Thread Starter
milotype2
Hello, I have a problem with my 94 Grand Cherokee. It doesn't do it all the time. It seems like after driving it for a while when I turn the wheels sharp, say while parking or turning into a drive, the front wheels seem like they want to lockup, then release, then lockup , then release, on and on. I can feel it through the steering wheel like its pulling at the wheel. The passenger side drive axle has been replaced so I pulled the drivers side and the best I can tell theres nothing wrong with the cv joints. I don't have alot of money right now and don't want to just start replacing parts at random. Any advice would be greatly appreciated! Thanks in advance!
milotype2 is offline
post #2 of 9 Old 09-03-2003, 03:09 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sounds like your viscous coupler is going out.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 9 Old 09-03-2003, 03:28 PM
pygocentrus
i think i have the same problem in my 98, but i think its my tires, im not sure.
pygocentrus is offline
post #4 of 9 Old 09-03-2003, 04:08 PM Thread Starter
milotype2
What is a viscous coupler? Is it in the differential? Thanks!
post #5 of 9 Old 09-03-2003, 05:08 PM
Stocker
No, it's in the transfer case. It allows the tires to rotate at different speeds in tight turns, and will bind up when warm if it's failing.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #6 of 9 Old 09-03-2003, 05:21 PM Thread Starter
milotype2
Sounds like it could be the problem. I suppose you all know the next few questions. How much? How hard? Can I do it myself? Does the transfer case have to come out? Thanks!
post #7 of 9 Old 09-03-2003, 05:54 PM Thread Starter
milotype2
You know, I just got to thinking about it. How would the transfer case control how fast each of the front wheels turn when they are connected through a single driveshaft to the front differential? The differential controls the problem of the wheels turning at different speeds when turning the vehicle. Someone correct me if I'm wrong. Thanks again for any advice.
post #8 of 9 Old 09-03-2003, 06:00 PM
Stocker
Good questions all. While waiting for much better replies than I am qualified to give, try searching here and at http://www.jeepsunlimited.com/forums/ and http://www.nagca.com/nagca.htm . Good luck!
Stocker
Stocker is offline
post #9 of 9 Old 09-03-2003, 06:04 PM
Stocker
You are correct as to the front diff, but when turning, the front tires travel a greater distance than the rears. The VC in the t-case allows for the difference in rotation speed - until it fails.
Stocker
Stocker is offline
locking problems 04ColumbiaWJ ZJ Grand Cherokee Forum 0 12-30-2009 01:36 PM
Warn locking hub clicking, front end not locking bigbluezj94 ZJ Grand Cherokee Forum 23 12-30-2009 06:47 AM
Locking Problems Deer_Slay3r ZJ Grand Cherokee Forum 7 04-27-2009 08:25 PM
Can having 1 front uca 1/2" longer then the other cause problems with steering? bjl95mustang ZJ Grand Cherokee Forum 15 06-27-2007 02:19 PM
locking wheels on 95 grand cherokee Rmen ZJ Grand Cherokee Forum 2 09-28-2005 04:01 PM
