Steering problem - JeepForum.com
post #1 of 16 Old 05-31-2007, 03:46 PM Thread Starter
13BTOY
Steering problem
Hey guys I'm having problems with my 97 GC limited. It will not move when the steering wheel is fully turned. For instance say I'm in a parking lot going about 5mph and try to make a tight turn which requires me to turn the wheel fully it will actually stop when it reaches a certain point as if something is holding it back. I thought it was my passenger side cv shaft(boot was torn) so I replaced it and it still does it. The driverside was just replaced a few months ago as well. Can someone please point me to the right direction? At a complete lost on this one.
Thanks, Ed
BTW both sway bar ends and steering dampner were replaced last year.
13BTOY is offline
post #2 of 16 Old 05-31-2007, 03:54 PM
gunthagunth
gunthagunth's Avatar
vehicle year/motor/transfercase type would help as it is probably a all time 4wd problem.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #3 of 16 Old 06-01-2007, 05:23 AM
kevsjeep
2006 WK
I have the same problem and based on information that i have got from this site i think i have a VC problem. Maybe you have too. Good luck in sorting it.
Kev
2006 Black WK Overland
#140 Black WK Club.
kevsjeep is offline
post #4 of 16 Old 06-01-2007, 02:35 PM Thread Starter
13BTOY
My Jeep is a 97 with a 5.2, full time awd. The thing is this problem is not constant. I notice its there after driving the vehicle for longer periods of time ie. not going to the store down the street and back but more so like 30-45 min. on the highway. Any clue? I hope its not the TC coz that started humming and whirring about 3 months ago. This thing just broke 70,000 miles!
Thanks, Ed
13BTOY is offline
post #5 of 16 Old 06-01-2007, 02:38 PM
AgitatedPancake
yeah that really sounds like your viscous coupler, the thing that makes the all-time 4wd work so well. It's inside your trasnfer case, and from what ive read here costs about 1,000 to have a shop replace it for you.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #6 of 16 Old 06-02-2007, 06:57 AM Thread Starter
13BTOY
Man I was hoping that wasnt it but I guess now would be a good time to swap and upgrade the TC. Aside from the VC going bad is there anything else I should check out first?
Thanks, Ed
13BTOY is offline
post #7 of 16 Old 06-02-2007, 07:16 AM
gunthagunth
Pull the front driveshaft. Pretty easy to do. Just remove the bolts, and pull the shaft around until it compresses a bit so you can remove it. Then take it for a drive and see if the problems are gone. When your done, put the shaft back in.
post #8 of 16 Old 06-03-2007, 07:15 PM Thread Starter
13BTOY
Do I have to drain it first?
Thanks, Ed
13BTOY is offline
post #9 of 16 Old 06-03-2007, 07:19 PM
gunthagunth
nope just remove the front driveshaft. No fluid will come out of the front driveshaft.
post #10 of 16 Old 06-03-2007, 07:20 PM
GRDCHRKE555
nope. no draining required. there is no fluid where you pull the shaft at.
Kyle
99 XJ Classic, 4.0, AW4, 8.25 Rear
4.5" (~6'') RC lift w/ full leafs, RE 1.25" Shackles, Bilstein 5125's, IRO Custom HI-Clearance LA's,JKS quicker discos, C4x4 Front Hooks, TW's SYE/CV DS, FLO-PRO cat-back, and some 32'' x 11.50" Maxxis Bighorns
GRDCHRKE555 is offline
post #11 of 16 Old 06-04-2007, 05:09 AM
kevsjeep
2006 WK
Yep, as you are finding mine is a lot worse when i have driven the car for a long time. I assume the fluid is over heating.
Kev
#140 Black WK Club.
kevsjeep is offline
post #12 of 16 Old 06-17-2007, 09:13 PM Thread Starter
13BTOY
I'm going to pull the shaft out tommorow. How long can I drive without it?
Thanks, Ed
13BTOY is offline
post #13 of 16 Old 06-17-2007, 09:33 PM
MuddyLuxury
MuddyLuxury's Avatar
Thanks, Ed
mine has been out for 3 or 4 months now....no problems
MuddyLuxury is offline
post #14 of 16 Old 06-18-2007, 08:45 AM Thread Starter
13BTOY
Really, so this has no ill effects?
Thanks, Ed
13BTOY is offline
post #15 of 16 Old 06-18-2007, 09:25 AM
MuddyLuxury
Thanks, Ed
Nope...its all good, i am changin the pinion yoke this week
Steering problem foxyfox ZJ Grand Cherokee Forum 4 08-17-2008 08:59 AM
Steering problem?!? lakailimited06 ZJ Grand Cherokee Forum 4 09-20-2007 10:15 AM
Steering Problem... EmericianIdol ZJ Grand Cherokee Forum 4 07-02-2007 05:25 AM
steering problem Reloader77724 ZJ Grand Cherokee Forum 8 12-15-2006 12:23 PM
Steering Problem bigjeep39 ZJ Grand Cherokee Forum 2 05-23-2005 04:12 PM
