Steering problem - JeepForum.com
post #1 of 3 Old 05-12-2007, 06:06 PM Thread Starter
DTrem08
Steering problem
So I went offroading today and got stuck in mud, ended up sinking to about the top of my tires. A friend towed me out with his f350, using a chain. Im not sure what he hooked it up to as I have no recovery points, but it was on the drivers side. When I was driving home, I noticed that I was getting death wobble when I hit 45-50mph....what do I do to fix this. My 96 ZJ is stock, no lift so I have no clue.
**LOOKING FOR MY JEEP, LAST SEEN IN CT and CURRENTLY HAS CT PLATES
White 1996 Grand Cherokee Laredo, I6 4.0 20% tint all around
**KOR Radiator Support, IRO 3.5" lift, 31/10.5/15" Maxxis Bighorns on 15x8 Cragar Soft 8's, JKS Bar Pin Eliminators, KOR Light Bar, 4 Black KC HiLites, Flowmaster Super 44 with turndown/no tailpipe, OME Steering Stabilizer, Black KOR square rock sliders
**If youve seen it around CT or know about it, PM me
DTrem08 is offline
post #2 of 3 Old 05-12-2007, 06:10 PM
wheelNC93
I think you might just have alot of mud built up in your tires. Sometimes when you go in deep mud it will cake to the inside and cause bad DW because they are out of balance.
wheelNC93 is offline
post #3 of 3 Old 05-12-2007, 06:17 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Death wobble is more commonly caused by a variety of things out of spec mostly in the front end.
I doubt that it is being caused from the rear end unless ypu have a busted shock or sway bar end link.
I second the mud on the tires, and it being only the beginning of it, as it is usually a sign of worn out parts like track bar bushings, or the like.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
Steering problem foxyfox ZJ Grand Cherokee Forum 4 08-17-2008 08:59 AM
Steering problem?!? lakailimited06 ZJ Grand Cherokee Forum 4 09-20-2007 10:15 AM
Steering Problem... EmericianIdol ZJ Grand Cherokee Forum 4 07-02-2007 05:25 AM
steering problem Reloader77724 ZJ Grand Cherokee Forum 8 12-15-2006 12:23 PM
Steering Problem bigjeep39 ZJ Grand Cherokee Forum 2 05-23-2005 04:12 PM
