Steering locking....need some help... - JeepForum.com
post #1 of 8 Old 02-16-2003, 03:35 PM Thread Starter
Silver1.8T
I have recently moved my 96 ZJ limited to Vermont where it is very cold. Recently when starting my car after it has been sitting in the cold over night or longer, the steering wheel will not move. It is not the same as when the steering locks when the car is off and you have to jiggle the key. This is when the car is on and you can move the wheel very little but it is not driveable. Then miraculously it starts to work. The first time it happened it took about 10 secons to go back to normal, then the second time it took about 45 seconds. Is this a serious problem with the steering rack or something? Or could it just be something freezing or something? Could low power steering fluid cause this? Thanks alot.
Silver1.8T is offline
post #2 of 8 Old 02-16-2003, 04:19 PM
Beachead19
Beachead19's Avatar
I would definatly check that power steering fluid. It sounds as if your level is low, so the fluid that is in there is taking longer to do its job. Also check and see if the bearings on the power steering pump are squeeking, that could mean you will have a failure really soon.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #3 of 8 Old 02-16-2003, 06:17 PM Thread Starter
Silver1.8T
checked the power steering fluid and it is at the proper level. How would I check the bearings?
post #4 of 8 Old 02-16-2003, 07:49 PM
Beachead19
Beachead19's Avatar
With the engine running, if the bearings or anything else are worn, the serpinetine belt spinning on the pump will make a squeeking/grinding noise.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
post #5 of 8 Old 02-16-2003, 07:52 PM
crazynut52
Same Problem!
I have a 96 ZJ and have the same problem with cold weather and my steering on startup, I have also heard about other people having the same problems with the're ZJ's. I believe this is a common problem
crazynut52 is offline
post #6 of 8 Old 02-16-2003, 08:10 PM Thread Starter
Silver1.8T
There does not seem to be any squeeking or such. Is this something I should be worried about? Coult the steering rack fail??
post #7 of 8 Old 02-16-2003, 08:20 PM
crazynut52
long time
My ZJ has had this problem since I have owned it, 1.5 years. I dont believe it is getting ready to fail as it has not worsened in this time, but it is definitley an inconvience. If there is a solution I would like to hear about it. The dealer told me not to worry about it, as it was very common, unless it remains a problem when warm.
post #8 of 8 Old 02-17-2003, 01:19 AM
Swamp Boy
Swamp Boy's Avatar
Make sure your belt is tight ..I have never had this problem
maybe its the cold weather .you could ask auto parts store if there is some type of additive to either remove water or prevent freezing/gelling or you could just move to a warmer climate..
Just another soccer moms Grocery getter....
Swamp Boy is offline
Warn locking hub clicking, front end not locking bigbluezj94 ZJ Grand Cherokee Forum 23 12-30-2009 07:47 AM
Voltage Drops with A/C and Steering starts locking up hunchback ZJ Grand Cherokee Forum 4 11-21-2009 04:33 PM
Locking the D30 bunjy1 ZJ Grand Cherokee Forum 24 06-05-2008 08:55 PM
locking hub? randyszj94 ZJ Grand Cherokee Forum 10 06-11-2007 10:10 PM
steering problems/front wheels locking milotype2 ZJ Grand Cherokee Forum 8 09-03-2003 07:04 PM
