Steering is driving me nuts - JeepForum.com
post #1 of 23 Old 09-16-2017, 11:43 AM Thread Starter
Mopar4U
96 zj limited 5.2 awd 133,000 miles. Stock no lift
Still wanders down the road, left right left right.
Has new:
Moog track bar with grade 12.9 m10 bolt torqued to 80ft lbs. axle side hole has been cleaned up and is as tight as can be without being a press fit.
Spicer upper and lower ball joints
Rebuilt steering box
Front and rear sway bars are rebuilt with moog bushings and links
Moog tie rod ends
Moog drag link
Steering stabilizer shock
Alignment was done
I havent done any control arms. Alignment shop said they seemed ok and im not sure how to verify if they are good or not. Previous owner put new napa control arms on about 30,000 miles ago but i cant tell if he did the upper pressed in bushing.
Suggestions?
Mopar4U is offline
post #2 of 23 Old 09-16-2017, 02:06 PM
GOLDWING
Did you check the steering box before you installed it? When I replaced mine with a low mileage JY part I went through the adjustments per the FSM. I checked my work with a dial indicator and had almost zero slack between input and output. The adjustments MUST be done with the box out of the vehicle.
GW
2 '98 4.0 ZJs
Hers is stock, mine, OME shocks, BB, Aussie, 2x6 sliders, 31s, etc.
GOLDWING is online now
post #3 of 23 Old 09-16-2017, 02:23 PM Thread Starter
Mopar4U
GW
I didnt, description said pre-calibrated. steering feels firm, doesnt feel like dead spots.
Mopar4U is offline
post #4 of 23 Old 09-16-2017, 05:17 PM
nicyousuckk
What kind of rebuilt box? Many of them are junk straight out of the box.
nicyousuckk is offline
post #5 of 23 Old 09-16-2017, 05:23 PM
jrobeson18
+1 I had to get one from crown to get a good one. I think I went through 8-10 from Carquest/napa. got the crown from kolak.
1997 ZJ 4.0 4x4, 190.5K, Rebuild 42RE, VIC delete Cubby, Cup holder insert, 5.9 Sound Bar, Logan's retrofit HID Projector headlamps, and much more to come
jrobeson18 is offline
post #6 of 23 Old 09-16-2017, 05:29 PM Thread Starter
Mopar4U
its a lares
https://www.rockauto.com/?carcode=1182192&parttype=7416
does it matter that i have the speed porportional steering?
Mopar4U is offline
post #7 of 23 Old 09-16-2017, 05:59 PM
nicyousuckk
Originally Posted by Mopar4U View Post
I wouldn't be at all surprised if that was your problem.
I'm currently on my 3rd napa box... I first replaced my steering gearbox because the stock ZJ one was puking fluid. Instantly the steering got much looser when I installed the reman. box. That one started leaking about a year later, second one was dead out of the box (acted like it had no power steering), third one has started leaking within about six months.
My next purchase will either be a crown from Kolak or a new PSC/AGR gearbox.
post #8 of 23 Old 09-16-2017, 07:53 PM Thread Starter
Mopar4U
wow, those are $300+! are there any good options that wont break the bank?
Mopar4U is offline
post #9 of 23 Old 09-16-2017, 08:39 PM
nicyousuckk
I guess it depends on your definition of "good". You could play gearbox roulette with the parts store's reman pieces and hope you end up with a good one. How much do you value your time and effort? It takes me about 3 hours to replace a steering gear box (with system bleed).
I'm really not sure how much Kolak charges for a crown box but I guarantee it's a good price for what you're getting. PSC/AGR are quite expensive but I've heard good things about both products.
post #10 of 23 Old 09-17-2017, 07:31 AM Thread Starter
Mopar4U
Kolak price is $360. Redhead is around $300 + core.
I think what im gonna do is disconnect the input/intermediate shaft from the box and try rotating the input shaft to see if there is slop. If there is slop can it be fixed by doing the preload and over the top adjustment?
Mopar4U is offline
post #11 of 23 Old 09-17-2017, 11:26 AM Thread Starter
Mopar4U
also wondering if there is any advantage of going to the durango steering box if i remain all stock?
Mopar4U is offline
post #12 of 23 Old 09-17-2017, 11:44 AM
GOLDWING
I would recommend against adjusting the steering gear box in the vehicle.
GW
2 '98 4.0 ZJs
post #13 of 23 Old 09-17-2017, 03:41 PM
nicyousuckk
Not really, I didn't mention it but all the boxes that have been on this ZJ have been Durango boxes. No need when you're running stock tires.
GW
Meh... it can be done. The bearing preload adjustment is much easier when the box is on the workbench, and the over-the-center adjustment should be made while the vehicle is drive-able. Toss up.
post #14 of 23 Old 09-17-2017, 05:47 PM
GOLDWING
The FSM says pull it to adjust it. Keep in mind that the worm gear thrust must be adjusted first, and then the over center adjustment. I question how you can rotate an inch pound torque wrench on the shaft while the box is installed.
GW
2 '98 4.0 ZJs
post #15 of 23 Old 09-17-2017, 06:02 PM Thread Starter
Mopar4U
what usually wears that causes slop? worm gear? output shaft? bearings?
reason i ask is there are some really nice write ups and youtube videos on how to rebuild these. if neither of the shafts or housing is bad i see no issue in rebuilding one of these.
Mopar4U is offline
