Steering Components - JeepForum.com
post #1 of 12 Old 08-23-2013, 02:23 PM Thread Starter
rj_osborn
Steering Components
I need a new tie rod and probably should replace my drag link while i'm at it. Any suggestions on upgraded components or are stock ones ok? I have about 4 inches of lift.
rj_osborn is offline
post #2 of 12 Old 08-23-2013, 05:05 PM
ZJ24
If you're looking to save a little money I would just buy the ZJ V8 steering. You can get it from a junkyard or new at your local auto store or rockauto for pretty cheap. I know crown sells it as a kit. There are plenty of threads on it if you search ZJ v8 steering. Or if you're looking to upgrade I recommend Iron Rock Offroads OTK steering system I have it and love it. And I've read a lot of good things about currie steering
ZJ24 is offline
post #3 of 12 Old 08-23-2013, 05:44 PM
jetjr91
Currie's currectlync is a nice upgrade no modifications needed fits in place of the stock steering linkage
jetjr91 is offline
post #4 of 12 Old 08-23-2013, 06:08 PM
jabba974
For "stock" replacement parts, I would go with Moog...they are an improvement over factory and the standard over the counter stuff....Cost is a little more, but I beleive they come with a life time warranty...
jabba974 is offline
post #5 of 12 Old 08-23-2013, 06:54 PM
ctak24
The Crown kit is priced very well, comes with tie rod, drag link, and all four end links.
Much more beef than the stock setup and cheaper than sourcing each part individually.
ctak24 is offline
post #6 of 12 Old 08-23-2013, 07:05 PM
kg6mov
Hears the voices
kg6mov's Avatar
The crown hd seems to be a favorite, same geometry as stock and stronger than the 4.0 links.
kg6mov is online now
post #7 of 12 Old 08-23-2013, 07:12 PM
ngould1
I'd use advance auto for the tie rod ends. Use in store pick up and this discount TRT37 $30 off $75.
Moog tie rod ends: Part No. ES3096L-- Part No. ES3094L-- Part No. ES3095R. Options..
You can get both tie rod ends for 63 bucks after discount.
ngould1 is offline
post #8 of 12 Old 08-23-2013, 09:16 PM
Kolak
Vendor
Kolak's Avatar
PM me for pricing on the Crown kit. It's really heavy duty, complete including new adjuster sleeves, and well-priced.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #9 of 12 Old 08-23-2013, 09:33 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I have the crown kit from Kolak. Well worth it.
Sent from my iPhone 6 using JeepForum
In the garage: M1 4bbl
McCloudsZJ is offline
post #10 of 12 Old 08-23-2013, 11:16 PM
kg6mov
Hears the voices
kg6mov's Avatar
My niner will be getting the same.
Unless you've done the WJ knuckle swap it's the way to go.
post #11 of 12 Old 08-25-2013, 07:47 PM Thread Starter
rj_osborn
Thanks for the input guys. I have a v8 zj. I kinda like the iron rock offroad otk steering kit but I couldn't find it in left hand drive on their website for some reason. Going to call them tomorrow.
post #12 of 12 Old 08-25-2013, 07:50 PM
WhiteOut
WhiteOut's Avatar
I'd look at the Currie system over the IRO. No replacing heims and no noise, both of which will occur with the OTK
WhiteOut is offline
