Steering column issues - JeepForum.com
post #1 of 3 Old 07-11-2013, 05:38 PM Thread Starter
Jeeples
Jeeples's Avatar
Alright, I just finished up swapping out my heater core and got everything back together. The good news is I only have one bolt and a couple of trim screws that didn't find their way home.
However the bad news is that I now have a considerable amount of up and down play in my steering column. It appears the movement is coming from the area where the column passes through the firewall. I have also noticed that I can see daylight in that area as well.
Any ideas?
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #2 of 3 Old 07-11-2013, 05:51 PM Thread Starter
Jeeples
Jeeples's Avatar
After a little more searching around, it appears that maybe my steering column mounting plate is bad. The rubber seal looks like it separated from the plate.
Jeeples is offline
post #3 of 3 Old 02-18-2014, 08:33 AM
juanWJ
Same Issue with my WJ
Wondering if you ever got to the bottom of this. I have the same issue and had my heater core replaced by a local mechanic as well.
juanWJ is offline
