Steering is clunking at steering wheel extremes - JeepForum.com
post #1 of 9 Old 07-13-2009, 04:38 PM Thread Starter
eboyer7
Hi. I have a 95 Grand Cherokee V8 4x4. About 2 months ago I started noticing that my steering was clunky when the wheel was turned to either extreme of steering. By "clunky" I mean that there was a clunking noise, and the vehicle was noticeable slowed down by the clunking, as if the axle was trying to get over some bump or imperfection in an axle component. It only happened very near the steering wheel extremes, so this was only a problem when parking. So, I checked out my front axles, noticed the CV boots were completely torn, and so replaced the front axles with brand new ones. But, the clunkiness wasn't totally gone after that. It was better, but not perfect. Also, it happens more when reversing.
So, what could still be causing the clunking? The tires are the right size and there's no suspension mods on it. I looked underneath while someone else drove the vehicle at full steering, but couldn't figure out what the problem was (although, it was pretty hard to see everything under there).
eboyer7 is offline
post #2 of 9 Old 07-25-2009, 03:42 PM Thread Starter
eboyer7
My brother said the problem might be the clutches in the limited slip differential. The Jeep noticeably loses power when the clunking happens (in other words, the vehicle is noticeably slowed down), so maybe the clutches are worn out and not grabbing properly at the steering extremes. Anyone else think this may be the problem? I don't know much about LSDs (), but this sounds like a possibility. If it is the clutches that are wearing out, will this cause any problems? Like, would the LSD suddenly fail/break?
eboyer7 is offline
post #3 of 9 Old 07-25-2009, 03:58 PM
DigitalVex
Your NP 249 transfer case viscous coupler is shot. Search "NP 249 transfer case"
2013 JK Rubicon 2.5" Metalcloak Elite lift, JCR Defender front, JCR Vanguard rear, AEV wheels
DigitalVex is offline
post #4 of 9 Old 07-26-2009, 01:01 AM Thread Starter
eboyer7
Should I be in a hurry to replace the transfer case?
eboyer7 is offline
post #5 of 9 Old 07-26-2009, 01:38 AM
Virmagicus
Virmagicus's Avatar
Sounds like it to me as well. Try this .... drive your jeep around for awhile and get it nice and hot. Do some figure 8's in a parking lot. Try to coast through the turns. If it want to bind and hop real bad it is the VC inside of the transfer case. A very bad/binding VC will wear your front end parts (your new CV's)very fast.
Jeff
Virmagicus is offline
post #6 of 9 Old 07-26-2009, 01:57 AM Thread Starter
eboyer7
I did that figure-8 test a while ago when I first discovered the problem, and it does hop when coasting through the turns.
The problem is that I'm going on a 3500-km road trip starting tomorrow. But, I'm guessing this worn VC will only cause problems for the front end parts (or other parts?) when turning sharply, and hence not cause too much trouble on the highway? *fingers crossed*
eboyer7 is offline
post #7 of 9 Old 07-26-2009, 02:02 AM
Virmagicus
Virmagicus's Avatar
Yes , the stress is only applied when turning but the VC will want to lockup more the hotter it gets. A 2,174 mile trip is pushing it but as long as the VC does not totally lock up you will be fine driving straight. Some have driven on a bad VC up to 150,000 miles. Each case is different though.
Jeff
post #8 of 9 Old 07-26-2009, 02:12 AM Thread Starter
eboyer7
Ok, awesome! I probably won't be doing more than 300 miles on any given day, so it won't be a stressful trip for the Jeep. I'll definitely look into it when I get back.
Btw, would a worn VC be caused by shifting the transfer case out of 4-low at 20mph rather than 5, or whatever Jeep suggests? Cause I accidentally did that when I first got the Jeep, having forgotten what speed to shift at.
eboyer7 is offline
post #9 of 9 Old 07-26-2009, 02:17 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
no, the vc is a wear item and will fail at any point after about 75k miles.
ratmonkey is offline
had 4 wheel aligment twice i past week, and steering wheel is still off center..Help HD-ZJ ZJ Grand Cherokee Forum 4 11-24-2009 01:54 PM
Steering Box Leaking and Clunking From Front End Joeyicu ZJ Grand Cherokee Forum 12 09-13-2009 09:57 PM
broken steering column / steering wheel loose? theksmith ZJ Grand Cherokee Forum 2 04-19-2009 09:49 PM
Steering wheel highryder08 ZJ Grand Cherokee Forum 3 07-05-2007 11:25 AM
steering and steering wheel acting wayyy differently GRDCHRKE555 ZJ Grand Cherokee Forum 10 03-22-2007 07:20 PM
