Steering Box Options? - JeepForum.com
post #1 of 9 Old 01-10-2014, 02:23 PM Thread Starter
ElCaminoManT
need to replace the steering box/gear on the 93, the sector shaft has all sorts of slop and she drives really bad on the road. have already replaced all of the control arms, track bars and steering linkage.
since it seems to hit n miss when buying a reman from the parts stores, im going to keep my eyes out for a unit from the bone yards from a lower mileage vehicle. will the units from XJs and TJs work? not really interested in the durango box
1993 Jeep ZJ Laredo 4.0L/42RE/242/D30/D35
ElCaminoManT is offline
post #2 of 9 Old 01-10-2014, 02:29 PM
Timo_90xj
Timo_90xj's Avatar
XJs work, but IIRC TJs at some point switched to a different box on the later years. IIRC also YJ power steering boxes should work too, but they're starting to be faily high mile/ old units.
***Under construction***
Timo_90xj is online now
post #3 of 9 Old 01-10-2014, 04:16 PM
shaban
I've had XJ pump in mine, it's got less reduction rate (thus, less steering wheel turns and harder to turn).
Watch out if you've got a speed-proportional pump, FSM says it doesn't go well together with non-proportional gear,
however I havent noticed any bad (mine's speed proportional).
shaban is offline
post #4 of 9 Old 01-10-2014, 06:54 PM
Smokey1r
If you get a JY steering gear, rebuild it if there is anything in question, its out and serviceable!!!
If you have speed proportional steering you can convert a non SP box easily by removing the spool valve out of the old box and installing it in the replacement box, or just replace the entire valve body assembly in to your replacement steering gear.
Smokey1r is offline
post #5 of 9 Old 01-10-2014, 10:52 PM Thread Starter
ElCaminoManT
how do i know if i have speed proportional steering?
post #6 of 9 Old 01-10-2014, 11:00 PM
Smokey1r
I doubt seriously you will have SPS on your 93 but the donor box might if its the only good one and out of a 96 through 98 jeep grand, but you will see the added electrical connection on the power steering pump if its still there?. and your spool valve will be slightly different in the steering gear.
Worse case is if your using a steering gear with SPS and you didn't change out the spool valve it will not act like the normal hydraulic assist you had before!
Smokey1r is offline
post #7 of 9 Old 01-10-2014, 11:25 PM
PolkaPower
SPS was only on 96 zj's
PolkaPower is online now
post #8 of 9 Old 01-11-2014, 08:13 AM
Technohead
Don't screw around with junkyard junk. PSC has reman'd units.
-Eric
Technohead is offline
post #9 of 9 Old 01-12-2014, 01:33 PM
Sandy97ZJ
Yeah don't junk around with steering boxes. I put a new box with snow plow for a durango from napa in my '97. I love it. Go for the one without if you want the faster turn radius (I didn't want that). It bolted right up in my 97.
Sandy97ZJ is offline
