Steering Box Adjustments - Fix your Floppy Steering - Page 5 - JeepForum.com
 1Likes
post #61 of 70 Old 12-26-2012, 09:58 PM
lennlin
will this kind of project be difficult for a guy who only really knows how to change his differential fluids, transfer case fluids and basic things like that? or should i just bring it to the mechanic?
lennlin is offline
post #62 of 70 Old 12-27-2012, 05:33 AM
comptiger5000
That level of skill is plenty to do the over-center adjustment (the nut on top of the box). If you're decent at figuring things out, the writeup is probably enough to get you through the process of doing the bearing preload adjustment too.
comptiger5000 is offline
post #63 of 70 Old 01-02-2013, 03:11 PM
OverlandZJ
Tightening things up after a lift install and found a clunk in my steering box, can actually see the sector shaft move a touch within the box. Found this thread.. thanks.
Have others had the slop in sector shaft and adjusted it out successfully or did you end up with a reman steering box or replacing bearings? My apologies if i missed that.
OverlandZJ is offline
post #64 of 70 Old 03-10-2014, 08:19 PM
jcjennings200
1994 ZJ
seems like I fix for my problems! thanks
jcjennings200 is offline
post #65 of 70 Old 06-28-2014, 06:44 AM
Jamieleague
steering wheel alignment
I have a 99 Grand and the steering wheel is off center by about 90 degrees when the wheels are straight. I was wondering if that is in the steering box or what the deal is or how to fix it??
Jamieleague is offline
post #66 of 70 Old 06-28-2014, 07:00 AM
riot1987
Your drag link needs to either be lengthened or shortened
brninitdwn likes this.
Build thread^^
riot1987 is offline
post #67 of 70 Old 06-28-2014, 08:45 AM
Jamieleague
great info have to check it out thanks for the quick reply
post #68 of 70 Old 03-13-2015, 08:03 AM
4LtrZJ
Riot: That is an awesome graphic. Thanks!
4LtrZJ is offline
post #69 of 70 Old 03-13-2015, 09:53 AM
riot1987
Yeah dude!
Build thread^^
riot1987 is offline
post #70 of 70 Old 02-24-2017, 01:06 PM
brjgto
Steering Box adjustment
Hi Harry, The pictures are no longer posted on the first post. Is there a way to repost the pictures?
brjgto is offline
Steering is clunking at steering wheel extremes eboyer7 ZJ Grand Cherokee Forum 8 07-26-2009 02:17 AM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 10:04 PM
broken steering column / steering wheel loose? theksmith ZJ Grand Cherokee Forum 2 04-19-2009 09:49 PM
difficulty steering/loss of power steering??? bsteele WK Grand Cherokee & XK Commander Forum 0 07-23-2007 10:46 PM
steering and steering wheel acting wayyy differently GRDCHRKE555 ZJ Grand Cherokee Forum 10 03-22-2007 07:20 PM
