Steering Box Adjustments - Fix your Floppy Steering - Page 3 - JeepForum.com
 1Likes
post #31 of 70 Old 09-12-2011, 02:53 PM
newfieZJ
I'm thinking more to back off the 'over the top' adjustment . You kinda indicate it bottomed out . I had much the same result once with that adjustment . I don't usually touch that one anymore , just the bearing preload . Moving it 2-3 mm per adjustment while on the jeep (5.9) It's taken most of the dead spot away with no bad effects . Gonna give it one more shot
newfieZJ is offline
post #32 of 70 Old 09-18-2011, 09:09 PM
Elite04GC
Great illustration! Thanks for the step by step with photos.
Elite04GC is offline
post #33 of 70 Old 09-28-2011, 06:20 PM
speedbucket
so i actually just pulled the box.
1. by "seat it in the housing" in the first adjustment....mine wont turn clockwise and there are 3 threads showing, im guessing you dont mean seat it flush with the box (then there would be no room for the lock ring right?) but just turn till it wont turn any more, then back it off .5"?
2nd, does anyone remember their rotational in/lbs that they were shooting for. i dont have a baseline for adding 6-10 in/lbs
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #34 of 70 Old 10-01-2011, 01:55 PM
muzicman82
2011 WK
Looks like a nice write-up. My '96 ZJ has around 357,000 miles on it, and the steering box is the original. I'm kind of thinking I should just replace it rather than adjust? Thoughts?
My steering isn't bad but it definitely isn't very tight.
Any thoughts on this one? Many of you know that Advanced Auto Parts has pretty good online coupon codes, so I can likely score this for $120 after I get my core charge back.
Input would be great!
2011 Jeep Grand Cherokee Laredo - 3.6L V6
105,000 (12/27/15)
1996 Jeep Grand Cherokee Limited - 5.2L V8
366,700 miles (4/21/12) (Laid to rest, but worked)
muzicman82 is offline
post #35 of 70 Old 10-01-2011, 02:13 PM
Smokey1r
Go to rockauto.com get the same box for $60.79 but dunno if the shipping would equal the same price at advanced or not...
Smokey1r is offline
post #36 of 70 Old 10-01-2011, 02:24 PM
Smokey1r
If anyone is having the continue to adjust the pitman shaft then its a good indicator the pitman shaft bearing is bad and is further deteriorating allowing room for more adjustments till the adjuster is bottomed out., might be high time to pull the box and replace the pitman bearing and seal, then redo the thrust bearing preload and over center adjustments and enjoy tight steering again, unless the worm shaft is worn out?.
Smokey1r is offline
post #37 of 70 Old 10-02-2011, 03:21 PM
speedbucket
Actually mine had a clunk at pitman and I was able to eliminate that via adjustment. I do have some play at the input shaft though. I have a dead spot at 12 o'clock. But I can atleast stay In a lane now._
post #38 of 70 Old 10-26-2011, 05:57 AM
93zjbums
do i have to adjust the center adjustment or can i take all the slop out with tightening the top part where the steering shaft goes in
93 zj laredo 4.0 with k & n intake 2 inch bb skyjacker shocks and 31 bfg at
92 chevy cheyenne 4x4 w/t with 32in procomps "The Beast" 184k
92 honda accord ex
92 xj stock 358k miles wifes
93zjbums is offline
post #39 of 70 Old 10-26-2011, 08:08 AM
comptiger5000
Mine's definitely due for this. Has about 3/4" of play and a light clunk, even after doing the over-center adjustment. Hopefully this proves not to be too much of a PITA and fixes it.
comptiger5000 is offline
post #40 of 70 Old 10-26-2011, 09:30 AM
Smokey1r
In the past 3 weeks ive met the end of the stop gap adjusting the over center of the steering box, adjust it any further and i get a slight binding so i backed it off to the last adjustment plus the steering has a dead spot from 11 o clock to 1 o clock and is progressively getting worse. Happily i just received my replacement steering gear from a JY in Wyoming and it appears to be in excellent shape aside from the usual slight seepage of the seals, so ill be doing a full rebuild on it checking everything out to be certain there's no unseen problems. hopefully ill have the time to fully document the whole procedure and get the new to me box in the jeep ... finally get rid of the dead spot in the steering!!!
Smokey1r is offline
post #41 of 70 Old 04-30-2012, 09:24 AM
speedbucket
ok, so i got one for you
swapped in a reman durango box
i have some slight play in the sector shaft (pitman arm shaft) when its at full lock at either end but zero play at center
1.Is this in need of an adjustment on the top of the box allen head bolt?
also, lock to lock is 3 turns but there is a slight loss of turning radius
with my worn out factory box my 31s would rub my lowers
with this box they are about 1" from contacting the lowers at full lock....
im slightly confused by this
2. any thoughts on this??? and i havent touched my steering stops
post #42 of 70 Old 04-30-2012, 12:22 PM
deermjd
There are two versions of the Durango steering box: one for models with the snow plow option and one for those without. One of these boxes has a less of a steering range than the other. This could could less desirable for some people but in your case it sounds like it fixed your tire rubbing problem.
94 ZJ Laredo (sold)
98 ZJ TSI (sold)
92 YJ 4.0
deermjd is offline
post #43 of 70 Old 04-30-2012, 12:23 PM
Smokey1r
This is completely normal behavior for the Saginaw steering gear, the tightness at the center of the steering radius is to keep your center line steering tight stable with no play. This tightness extends to 45 degrees either side of center. The play increases as you turn further to the physical limits of the turning radius (full lock).
The Durango box could have a rack piston nut with shorter range of travel which would reduce slightly the turning radius despite the worm shaft having a 14:1 steering radius (3 turns lock to lock).
Smokey1r is offline
post #44 of 70 Old 05-21-2012, 08:45 PM
speedbucket
So I don't need to do anything unless I have play at the center of the sector rotation? I just don't want to blow the seal or break the shaft if I'm at full lock wheeling
I did adjust my turn stops on the knuckle to match the box so I don't over extend it.
post #45 of 70 Old 05-21-2012, 08:48 PM
speedbucket
Mine is not tapped for the hydro attachment line
Steering is clunking at steering wheel extremes eboyer7 ZJ Grand Cherokee Forum 8 07-26-2009 02:17 AM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 10:04 PM
broken steering column / steering wheel loose? theksmith ZJ Grand Cherokee Forum 2 04-19-2009 09:49 PM
difficulty steering/loss of power steering??? bsteele WK Grand Cherokee & XK Commander Forum 0 07-23-2007 10:46 PM
steering and steering wheel acting wayyy differently GRDCHRKE555 ZJ Grand Cherokee Forum 10 03-22-2007 07:20 PM
