Steering Box Adjustments - Fix your Floppy Steering - Page 2 - JeepForum.com
 1Likes
post #16 of 70 Old 02-09-2011, 09:15 PM
mtbonia
1994 ZJ
Great thread! This is exactly what I was looking for in terms of tightening up the steering. About how long did it take for you to do this?
This is beyond my skill range but I have a friend with a shop
mtbonia is offline
post #17 of 70 Old 02-10-2011, 03:05 AM
TheHalfWit
Op said 2 hour job in his post, and if you have a friend with a shop see if you can watch, maybe you'll learn something interesting.
TheHalfWit is offline
post #18 of 70 Old 02-10-2011, 12:34 PM
mtbonia
1994 ZJ
Thanks, I missed that part. Yea and maybe if I help him he'll charge me less too
mtbonia is offline
post #19 of 70 Old 02-10-2011, 06:34 PM
MurdaJs
Great writeup
MurdaJs is offline
post #20 of 70 Old 02-14-2011, 09:05 AM
mtbonia
1994 ZJ
Just want to make sure before I pull the steering box out; the adjustment procedure is the same for a 1994 (I see you have a 1996), right?
mtbonia is offline
post #21 of 70 Old 02-14-2011, 10:54 AM Thread Starter
Yardman Harry
O
Yardman Harry's Avatar
Yep
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #22 of 70 Old 02-20-2011, 03:42 PM
soldsrt8
thanks harry im going to try it i have 6 inch lift on 95 wandering alot changed track bars change alot of parts 3 alinements and the same. Hope it works
soldsrt8 is offline
post #23 of 70 Old 02-26-2011, 10:11 AM
01GS
Does anyone know the size of the nut on the steering box arm? My biggest socket is a 32mm and it wouldn't fit on there but was close.
01GS is offline
post #24 of 70 Old 02-27-2011, 10:15 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
My ZJ is all over the place. The reman box from NAPA stayed tight for about a month.
I may attempt this project today. Also, I'll be installing a brand new AC Delco pump and a used Mopar tranny cooler as a PS cooler.
HighLonesome is offline
post #25 of 70 Old 02-27-2011, 04:49 PM
HighLonesome
Well, I've read this thread twice. After snugging the preload:
Yard says back off 13mm per the FSM
The TSM says back off 9mm
The notes at the bottom of the TSM say back off 3-5mm
any thoughts on this discrepancy?
post #26 of 70 Old 02-27-2011, 05:39 PM Thread Starter
Yardman Harry
O
Yeah, I saw that too. Are you using the TSB for the dodge truck? I went with the FSM because the TSB I found (and that which has been posted on this forum many times) is for a dodge pickup. So FSM wins. Although I had the same question.
So far so good though, the Adjustments are still proving to have helped the steering. My wife says its a pleasure to drive now.
Yard
edit: see, I was thinking the same thing, posted this back in January. FSM vs TSB
Hunter Green
White
~Junked~
post #27 of 70 Old 02-27-2011, 06:02 PM Thread Starter
Yardman Harry
O
Youre just shy, its 33mm for the pitman arm nut.
Hunter Green
White
~Junked~
post #28 of 70 Old 06-28-2011, 06:35 AM
speedbucket
the allen screw is the adjuster and the nut is the lock right?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #29 of 70 Old 06-28-2011, 04:46 PM
newfieZJ
Yes , the hex screw adjusts , the nut tightens it .
Andy , if you look up the specs on the 98 model year Grand Cherokee's , you would see the 98 FSM states 10mm . I would consider this the updated spec as the boxes are the same .
I adjust all mine to 10 mm
newfieZJ is offline
post #30 of 70 Old 09-12-2011, 02:24 PM
speedbucket
I opted to do try this while the box is still in, doing the over the center adjustment by tightening adjusting in small increments, it definetly helped but i believe my box is on her way out as the adjusting screw is bottomed out and she never made a hint of binding
maybe it had already been adjusted previously.
i am not returning to center well so im guessing just to back the bearing preload off a bit? sound right?
Steering is clunking at steering wheel extremes eboyer7 ZJ Grand Cherokee Forum 8 07-26-2009 02:17 AM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 10:04 PM
broken steering column / steering wheel loose? theksmith ZJ Grand Cherokee Forum 2 04-19-2009 09:49 PM
difficulty steering/loss of power steering??? bsteele WK Grand Cherokee & XK Commander Forum 0 07-23-2007 10:46 PM
steering and steering wheel acting wayyy differently GRDCHRKE555 ZJ Grand Cherokee Forum 10 03-22-2007 07:20 PM
