Steering Box Adjustments - Fix your Floppy Steering - JeepForum.com
post #1 of 70 Old 02-06-2011, 10:01 PM Thread Starter
Yardman Harry
O
Yardman Harry's Avatar
I have been wanting to do this now for a while. I have had crazy handling on my jeep, very scary.
Just some background and things to check first:
1. I found a lot of play in my trackbar bushings. So I purchased KOR durometer bushings, that tightened things up a bit.
2. I installed KORs steering brace, didnt notice a difference, but it minimized a clunk noise I had when turning my steering wheel.
3. Replaced a bad Tie rod end at the pitman arm, also reduced clunking, steering did not improve.
4. all other front end components are tight and new (bjs, control arm bushings...etc)
5. 2 alignments by two different shops, last one resulting in poor pinion angle causing front ds vibes. And my steering performance did not change.
So before I dropped the money for a brand new steering box, I decided to adjust mine, the proper way.
The first adjustment is to bearing preload, second is the over center adjustment.
1. People say this can be done with the box in the jeep... I cant imagine how it is done. Best to remove the thing, otherwise you will make a 2 hour job = 5 hours.
2. Remove the steering box from the jeep, if you have KOR brace remove that too because the box wont have enough clearance to drop with the brace in place. I couldnt get my hands down to the box to remove the pump lines, so I removed the lines at the pump instead of the box. Here it is out.
3. This end here is the stub shaft, it is where the steering column attaches to the box.
remove the lock nut to the adjuster by using a punch and a hammer,
removed
4. now take your wrench, I only had 90 degree needle nose pliers, and turn the adjuster clockwise until it is fully seated in the housing
5. Take a ruler and make an index mark at an adjuster hole, then measure .5 inches or 13 mm in the counterclockwise direction and make a second index mark
6. now turn you adjuster hole so that it is positioned/line up to the second index mark!
7. Put the lock nut back on the housing and tighten the crap out of it. BE SURE THAT THE ADJUSTER DOES NOT TURN DURING THE INSTALL OF THE LOCK NUT!!!
8. The next part requires that you find the center of the gear range, you have to turn the stub shaft...I found this rather difficult, so I took a 19mm socket, and folded up a rag, I pressed the socket over the rag onto the stub shaft, and it made a nice snug fit so that I could turn the thing with my wrench! This also allowed me to put my torque wrench on there to measure rotational resistance/torque.
8.a. Turn the stub shaft all the way to the end of its travel. Now turn it back in the opposite direction counting the number of turns (should be 3 and a 1/4ish turns) Now turn the shaft once again in the opposite direction for half of the turns counted in previous step. This will be the CENTER of the range!!
9. Loosen the center drag lock nut and turn the adjusting nut counterclockwise until it can turn NO MORE. Now turn the adjuster clockwise one full turn.
10. Put your tourqe wrench on the stub shaft and measure the highest rotational torque. Start your wrench in the vertical position and turn left to right to only 9 oclock then reverse to 3 oclock. Record the highest torque.
11. now turn your adjusting nut a little clockwise and remeasure the rotational torque of the stub shaft. Your goal is to get the shaft torque 6-10 in/lbs higher than the base reading measured in step 10.
12. after you have adjusted your center drag, put the lock nut back onto the adjuster and tighten to 20-36 ft/lbs (the FSM gives two specs for this torque, both 20 and 36. so pick one) Be sure that when you tighten your lock nut the adjuster does not turn!! I used my allen inside my socket to make the nut as tight as I could with my hands and pliers. Then I was able to torque the lock nut.
13. Install the box back into the jeep. Have fun!!
Some Special considerations:
1. Drain the box! I didnt and I made a mess, and the fluid builds pressure and you get resistance when turning the stub shaft, this can lead to bad torque measurements.
2. Get a helper to help you hold the bearing preload adjuster when you tighten the lock nut. That thing will turn when you tighten the lock nut.
3. it doesnt take much on the center drag adjuster to increase the rotational torque by 6-10 in/lbs. I think my adjustment ended up being about 1/4 of a turn.
4. Hold your allen wrench when measuring rotational torque on the center drag adjustment. I found that by turning the stub shaft with the center adjuster lock nut off, the adjuster was also turning. So I had to hold the adjuster while measuring torque.
Torque Specs:
Gearbox to frame bolts: 65 ft/lbs
Pitman arm nut: 185 ft/lbs
Yard
EDIT:
Additional input from NewfieZJ
FSM VS TSB
Just recently did a bearing preload on a box I had kicking around , it's still on the bench But yesturday , decided to try a preload on the MJ I have before swapping boxes , while it was still in the truck .
Going by memory of the TSB , I marked it only 9mm , instead of 13mm . I'm also pretty sure it moved down to 8 after it was tightened . Worked like a charm , hell , I am not changing the box after all , lol .
So that was all well and good . I began to reread some threads on here and reread your write-up , and also the tsb vs fsm thread .
I can certainly agree with the fact this was for a dodge Ram , not a jeep . What I will say is that because of this steering box TSB , I got curious .
All ZJ FSMs up to 1997(printed prior to the TSB) most certainly spec'd 13mm or .5" . however , this is where it gets interesting , the 98 speds 10mm .
Personally , I do think the info was updated , probably never made it to online accessability like the Rams and instead of 13mm , it was updated to 10mm and made print for the 98 model year FSM .
Either way , it's going to be alot tighter than it was before , does the 3-4 mm really matter ? Doubt it
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #2 of 70 Old 02-07-2011, 07:54 AM Thread Starter
Yardman Harry
O
Forgot to mention the results:
My steering responsiveness has increased by 100%. If I turn the wheel, the steering moves. Whereas prior to the adjustments, I had a good 1 inch of play
In addition, the steering is tight, feels like my TJ.
Road manners have also been enhanced. I no longer wander all over the road, my jeep doesnt pull to either side (depending on the slope of the road). And I can even feel that I actually have some minor bump steer.
Harry
Hunter Green
White
~Junked~
post #3 of 70 Old 02-07-2011, 08:33 AM
melk
Great write up. Thanks for taking the time to put it together.
melk is offline
post #4 of 70 Old 02-07-2011, 09:03 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
x2
Keeps the varmints on the run, boy
HighLonesome is offline
post #5 of 70 Old 02-07-2011, 09:13 AM Thread Starter
Yardman Harry
O
Thanks guys There has been a lot of talk these days about loose steering and steering wandering. Our ZJs are nearing 15-20 years old on stock steering boxes... time for adjustments and I was not happy with just doing an over the center adjustment with the box in the jeep.
I asked a while ago about replacing the sector shaft in my box due to a clunk it was making, this adjustment also tightened that looseness up. The cluck is gone.
Yard
Hunter Green
White
~Junked~
post #6 of 70 Old 02-07-2011, 09:36 AM
KJK
I did this to my steering box using a TSB I found online.
I did it with the box in the jeep (ZJ) and it was easy. As stated by you, it made all the difference in the world!
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #7 of 70 Old 02-07-2011, 03:14 PM
MuddSlutt
NICE! this will be one of my next fixes
01 WJ 4.0 ((New Toy))
98 ZJ 5.9 Limited ((SOLD))
MuddSlutt is offline
post #8 of 70 Old 02-07-2011, 04:20 PM
doomi
Awesome, looks like I have a project for Saturday!
doomi is offline
post #9 of 70 Old 02-08-2011, 06:11 AM
newfieZJ
Nice work Harry . Lots will benefit from this write up .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #10 of 70 Old 02-08-2011, 07:24 AM
tonymartin
Subscribed for sure. I gotta swap the pitman arm shaft seal soon so I guess I will attack this whilst I'm there!
thanks Harry
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #11 of 70 Old 02-08-2011, 07:36 AM
GDZJEEP
Great writeup. Thanks.
IT'S NOT A RELIGION...IT'S A RELATIONSHIP!
HPD44, RCV Axles, Ford 8.8 Rear, OX's front and rear, custom cage, sitting on 37" Goodyear Wrangler's.
www.facebook.com/gdzjeep
GDZJEEP is offline
post #12 of 70 Old 02-08-2011, 07:38 AM
Virmagicus
Virmagicus's Avatar
Nice writeup! Added to the FAQ
This adjustment should be the first thing to do when you have wandering steering to eliminate any other problems. Can cost some $ if it done last. What problems did you have without pulling the box Harry?
Jeff
Virmagicus is offline
post #13 of 70 Old 02-08-2011, 08:08 AM Thread Starter
Yardman Harry
O
Thanks Jeff
I just don't see how you can get an accurate measurement of torque resistance when measuring bearing preload. Or how you can even get your head down there to see the index marks you need to make. When the box is on the bench, you can see everything, especially when you tighten lock nuts and the adjusters turn on you
I guess if you were patient enough you could do this in the Jeep, just saying that with a $400 dollar part, take it out so that your measurments and adjustments are uber precise
Harry
Hunter Green
White
~Junked~
post #14 of 70 Old 02-08-2011, 01:55 PM
Tudds
That looks a little involved for someone like me. I think you inspired me to get a new box though. They are about 200 bucks on rockauto
Tudds is offline
post #15 of 70 Old 02-08-2011, 02:43 PM
ArmyVet717
Nice write up Yardman Harry!!
Now, if I can just find someone to help me out with this, or that can do it for me, I will be good! My property manager has already called me on "working" on vehicles. All I was doing is adding wiper fluid and checking my oil!! Talk about anal!!
I was in the same situation and had the shop replce all the ball joints, but they said tie rods were good. Took it to get aligned today, it is a bit tighter, but there is still some play and wander in it. My brain automaticall went to the steering box, my 65 GMC (no PS) used to do the same, but adjustment was fairly easy without having to take it off.
Thanks for pointing me in the right direction!! Now I don't have to put a new thread up about my steering!
'96 Grand Cherokee Laredo, 5.2L, NP242 Swap, Closing in on 300K miles, 4.5" RE lift, Tow Pig: 04 Dodge Durango SLT, 4.7L
http://www.facebook.com/#!/smontgomery717
ArmyVet717 is offline
Steering is clunking at steering wheel extremes eboyer7 ZJ Grand Cherokee Forum 8 07-26-2009 03:17 AM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 11:04 PM
broken steering column / steering wheel loose? theksmith ZJ Grand Cherokee Forum 2 04-19-2009 10:49 PM
difficulty steering/loss of power steering??? bsteele WK Grand Cherokee & XK Commander Forum 0 07-23-2007 11:46 PM
steering and steering wheel acting wayyy differently GRDCHRKE555 ZJ Grand Cherokee Forum 10 03-22-2007 08:20 PM
