Steering - JeepForum.com
post #1 of 8 Old 12-20-2011, 12:21 PM Thread Starter
zjilahi
2014 JK Wrangler
Steering
Hello Forum,
I have a 1994 ZJ V8 5.2. Ever since I got it the steering has been loose. I got the tie rod, tie rod ends, track bar all replaced. I also got the steering gearbox rebuilt. After getting all these replaced the steering looseness was dramatically better. The only problem is that when I am turning at above 30 MPH the steering wheel does not come back. I have to turn the wheel back straight myself. Also It still wanders a little on the road when I am going straight. I have to constantly turn the wheel back and fourth. What could possible be causing this? Any help would be much appreciated!
zjilahi is offline
post #2 of 8 Old 12-20-2011, 12:23 PM Thread Starter
zjilahi
2014 JK Wrangler
I also have got the steering stabilizer and shocks replaced.
zjilahi is offline
post #3 of 8 Old 12-20-2011, 01:45 PM
Exdecuk
You had a propper alignment done lately, castor, camber, toe check etc etc
Exdecuk is offline
post #4 of 8 Old 12-20-2011, 01:49 PM
JS97ZJ
x2^^
JS97ZJ is offline
post #5 of 8 Old 12-21-2011, 11:39 AM Thread Starter
zjilahi
2014 JK Wrangler
The shop had told me they had done the alignment.
zjilahi is offline
post #6 of 8 Old 12-21-2011, 01:47 PM
JS97ZJ
This problem sounds like the first and last time I had my first car serviced by any professional mechanic.
When they rebuilt your gear box they might have over torqued the adjustment screw in order to compensate for the loose front end.
Worn tires won't help in this situation either.
Get someone to turn the steering wheel back and forth, 10 o'clock then 2 o'clock positions, while you look at the steering linkages. EVERYTHING must move smoothly without wiggling or have any noticeable play.
To check the ball joints, lift each wheel off the ground, by jacking it up by the knuckle not the frame, just enough to get a big crowbar under the tire. Pull up on the crowbar, and check with your other hand, on top of the tire, for any sense of looseness. The top joint can be checked by grabbing the top and bottom of the tire, then alternately push and pull the top and bottom to see if there is any movement there.
If you find anything , your on your way to being a professional.
JS97ZJ is offline
post #7 of 8 Old 12-21-2011, 02:08 PM
PolkaPower
If those parts are stock and never been changed, all of it is overdue.
PolkaPower is online now
post #8 of 8 Old 12-21-2011, 04:20 PM
snotrod
try the over the center adjustment. I had your exact problems and that's what fixed it for me. check the FAQ's
1999 TJ, 4.0l 5sp 2" Rancho lift springs, Rancho 9000's
snotrod is offline
bad , problem , slop , steering
WJ steering, last part needed for brake/steering upgrade worsrider4047 ZJ Grand Cherokee Forum 20 04-02-2012 11:39 PM
New Steering Gear Box - 1 week later = easy power steering 3xX ZJ Grand Cherokee Forum 4 10-11-2011 03:03 PM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 10:04 PM
broken steering column / steering wheel loose? theksmith ZJ Grand Cherokee Forum 2 04-19-2009 09:49 PM
steering and steering wheel acting wayyy differently GRDCHRKE555 ZJ Grand Cherokee Forum 10 03-22-2007 07:20 PM
